Im sold on pto's they don't get the solution as hot, but they have alot less to go wrong
My Hydramaster and Cleanco get up to 205-210 degrees f. The newer ones with the Salsa or Max heat packages get up to 235-240 degrees f. I have a lot less problems with hoses bursting or wearing out.
Dwain Ray
What about hi
I got burned out with a portable setup. The mechanic was loosening a bolt on the undercarriage and the interior caught fire. $18000 worth of equipment and my van totaled. Thankfully I had insurance.
I get 200° from frankinstien it has a salsa unit the blower discharge temp on a 47 blower according to roots is 225° @ 14"hg so at 100% recovery (not possible) highest solution temp would be 225° my point was less problems with lower temps ,using exhaust to heat solution to super high temps creates more problems than it's worth
Dwain Ray
What about hi
Dwain Ray
Having a custom designed and built machine allowed me the freedom to pick and choose to best and most reliable components from all the manufacturers
Amtex? burned thru...what did it "want" to catch on fire?
what flammables were near it?
The HM? air cooled engine?
what caused the crank to break and how could you of prevented it?
The Everest?
oil pouring on the manifold could start a fire
The spraying AF was a built in sprinkler system...
the same JD that charged $26 bukz a pop of a $3 spark plug?
ask it if needs a new blower...
Just make sure you don't forget and leave the can of WD-40 or greasy rag laying on the exhaust manifold
and run the damn thing...
Cheap galvanized homemade exhaust headers literally burned in half. Don’t lecture me on tm safety
Oh probably about 5 grand a year company wide, not much...
If they actually put retired carpet cleaners on the sales floor, they'd probably sell 10 times that much
I’d be a bad sale sm for your glides. I’d tell all the weak ones to grow some manhood and use slotted only
KevinD
Kevin Dumas
My custom SS header system off my 40hp kohler into my heat exchanger cost 1k alone to build after burning through a couple oem's.
This was no OEM. He used the galvanized plumbing elbows screwed in to the welded pipes that were welded to the original mounts that screwed in to the engine. Then he covered it up with exhaust wrap to hide it.
KevinD
Kevin Dumas
I meant truckmount manufacturer when I said oem
Well, I ran it for about 2hrs today at my house cleaning up my tile and carpet. I ran great. This was the first time since I bought it that I'm pleased to say I can depend on it. It seems that gutting out the catalyst and pulling that junk out of that fuel injector fixed the problem.
Dwain Ray
It barely glowed very close to where it bolted to the engine. Even then it didn't glow the whole job
Aren't they supposed to glow?ive driven my vans more than once with the dog house off and noticed that the exhaust manifolds glowed, and while on a dino my Shelby headers glowed too. On the vans the manifolds would quickly heat up and glow under acceleration and quickly cool off when i let off the gas same on the mustang glow bright when doing a pull and cool right down as soon as you let up on the gas
Dwain Ray
I always read that glowing headers either was caused by lean fuel burn or bad catalytic converter. I had both problems and the glowing reduced almost 100%
I know some of these turbo engines in race cars are different, but a normal engine shouldn’t have a bright glow. My previous Titan and current Everest and now thermalwave don’t glow bright.
Next time I get bored, I’ll pull the doghouse off my van and see if it glows
Dwain Ray
I only saw the mustangs headers when it was under load on a dino and the vans exhaust manifolds glowed when i accelerated hard, so under load also .
I don't know anything about these carpet cleaner engines i just assumed that under load they would glow also. I just googled normal operating temperatures for catalytic converter
Dwain Ray
Ive been following this forum for awhile and assumed that glowing manifolds were normal, but im a pto guy and know next to zero about specific engines like yours my knowledge is more general
Whenever I get a pto, you’ll be harassed from me for certain
