What's up with lockdown?
Bryce C
DFW
Bryce
Sometimes my wand locks down on cut pile carpeting, but most of the time it doesn't. Just yesterday I was cleaning a cut pile carpet and the wand was locking down and very heavy to pull. I'm not sure what to do in those situations. The carpet had much more moisture left on it after my dry passes than usual.
I'm using a hole glide on an Evo 13" wand. It has some grooves going out to the side. They are worn down a bit, would carving them out deeper help prevent lockdown? Should I have a different glide to swap out in those situations? Would turning down the rpms on my machine to lower the vacuum power help prevent lockdown? I was running it at 1400 rpms with 100 feet of vacuum hose, which is at "medium" power in my CDS 4.8, maybe I should turn down the sauce on shorter hose runs.
I'd rather not wrestle against my wand and only end up with wetter carpet after my efforts. Any tips?
I"m really surprised to see a lockdown with that hole glide. Not normal for sure. But leave your settings on the machine as is. Can you remind us what the hg is set at on your machine?
Reactions: Bryce C
FredBoyle
Fred Boyle
Role
Years of Experience
38
Basic airflow dynamics
The wand seal is most commonly created on wool and nylon
Higher piles typically grab the wand more than shorter plush piles
If it’s too intense , I’ve dropped the Butler into Mach 1 , it helps airflow relief
Full lockdown is t moving air , it’s Just breaking Your body
View attachment 133873View attachment 133874
Hey I got one just like that one....
What's it worth?
Bryce C
DFW
Bryce
Ok thanks. The hg is set at 13.5. Although I just pulled my seal-a-door out from behind the waste tank that day. Maybe I bumped and adjusted the release! I'll check the gauge next time I use the machine tomorrow, I only had a commercial vlm job today.
was it a plush?
I'd say it was a medium pile carpet.
Have you burped your gauge in a while?
Reactions: Bryce C
Bryce C
DFW
Bryce
Good tips, thanks!
What's it worth?
The Evo 13"? About $900 these days.
Bryce C
DFW
Bryce
I asked Google AI about wandseal or lockdown on wool and nylon fibers and it just grabbed a bunch of unhelpful random bits of unrelated info about cleaning wool and nylon carpet and acted like it answered my question, it has no idea what wandseal or lockdown in carpet cleaning is. This was its answer:
""Wandseal (or "lockdown") refers to a phenomenon where cleaning lines, streaks, or a "locked-in" appearance of dirt appears on a carpet, usually caused by improper wand technique, excessive moisture, or chemical residue during cleaning. It is more common on wool and nylon because of their specific fiber structures and sensitivity to moisture and chemicals
Key Reasons for Wandseal on Wool and Nylon:
Absorbency and Wicking (Wool): Wool is a natural fiber that is highly absorbent, meaning it holds on to moisture and cleaning solutions. Over-wetting during cleaning can cause water (and dissolved contaminants) to sink deep into the backing. As it dries, this water moves back up to the surface, bringing hidden dirt with it—a process known as "wicking" or "lockdown".
Sticky Residue Attraction (Nylon): Nylon is durable, but when cleaned, it can leave behind soapy, high-residue, or sticky shampoo residue if not rinsed properly. This sticky residue acts like a magnet for dirt, making the cleaned paths appear dark again within a few weeks.
Heat and Chemical Sensitivity (Both):
Wool should not be cleaned with high temperatures (over 160°F) or highly alkaline solutions, which can damage the fiber and cause browning or "lockdown" of contaminants.
Nylon often requires specialized, lower-pH cleaners (especially stain-resistant nylon) to avoid damaging the protective coating, which if done incorrectly, causes rapid re-soiling.
Wand Technique & Suction Issues: Inadequate extraction (poor suction) is a primary cause of wandseal, leaving too much moisture in the carpet. If a technician uses excessive water or improper angles, it leaves linear "water marks" (wand lines) once the carpet dries.
How to Prevent It
Thorough Extraction: Ensuring the carpet is not over-wet is crucial, especially for absorbent wool.
Rinse Thoroughly: Using a proper rinse agent to remove all detergent residue prevents sticky, re-soiling (lockdown).
Use Proper Tools: For these fibers, professional-grade tools with high suction are necessary to prevent leaving residual moisture and detergent.
Proper Drying: Utilizing high-speed air movers to dry the carpet quickly after cleaning prevents wicking""
AI is not helpful, knowing that is helpful. I am curious, why is this phenomenon more common on wool and nylon fibers?
Never even heard of that 😲
I have not...
That little rubber cap on the top of the gauge behind the face of the machine. Pull it off. That releases any buildup of pressure in the gauge and resets it to make certain it’s reading accurately. If pressure is built up it might be turned up much more than 14hg, causing too much suction which could be locking the wand
But it doubt that would cause it since you are just using that hole glide. But it’s a good thing to check periodically
  • Love
Reactions: Bryce C
AI is a clueless kid copying off of an A student on his right and a D student on his left, and is incapable of knowing who is the smarter one.
What it is trying to do is to give you information on nylon and wool that it does “know” but it doesn’t understand the problem you are experiencing.
FredBoyle
Fred Boyle
Role
Years of Experience
38
That’s an interesting way of looking at how AI compiles data and creates a response
The difficulty on this query is that it is a very specific experience with not enough generally accepted “true” answers for AI to reply accurately
Hopefully The Cleaning Standard will assist in the accuracy
The internet has a tremendous amount of “ D student” carpet cleaning answers because anyone can add data whether it be accurate or not
AI will only function effectively with solid data in to extrapolate good responses
This site is good , but there’s a few D Students here as well
Reactions: Jim Pemberton
Bryce C
DFW
Bryce
Most excellent. Thanks Woody!
To quote something Mike would like, "we all fall short"
And Fred, let me add:
I appreciate that you've shown the spirit of kindness that we want in The Cleaning Standard in not pointing out those who might be striving to elevate themselves beyond the D level.
(And if not kindness, then at least restraint :biggrin:)
Reactions: FredBoyle
FredBoyle
Fred Boyle
Role
Years of Experience
38
“ empty vessels make the most noise “
Unfortunately AI is “ listening “
I'm a D student and my machine is so simple for dummies😀 How smart can you be when you clean floors and carpets and scrub toilets🤷🏼‍♂️🤣
Reactions: Dr. Kleen
As a guy who has met a lot of cleaning company start ups for nearly 50 years, these are the two things I have heard:
1. "Wow, I didn't know how physically demanding cleaning was!"
2."I didn't expect I'd have to know so much about dirt, stains, chemicals, and how equipment works!"
So I know you were joking Kenny, but with the expanded audience that we are getting with The Cleaning Standard, I want people to know that this isn't a business for the lazy or the stupid.
Of course I was kidding! Keeping up with 30 employees scattered over 3 plants is a full time job. We really do try to keep it simple for that reason, but I guarantee you if I was doing residential, it wouldn't be so simple. That which affect me the most, such as ride on scrubbers are complex.
Bryce C
DFW
Bryce
Carpet cleaning has been a journey of redemption for me. The good Lord led me to it in hopes that I would become more skillful and diligent, and a fruitful servant. The rewards that this work offers, and the demands that it makes, are just what I needed.
It seems that my laziness and foolishness was considered salvageable 😄
If you want a good adrenaline rush, start doing water damage
  • Wow
Reactions: Bryce C
He is using the smaller 1.5" Evo wand--
Perhaps the carpet/rug was rubber-backed or had PetSmart (urine "proof") padding, is my guess.
He used the word sometimes in the original post so carpets that are extremely dense like the rubber back type that you're suggesting could be an issue
The side channels channels he spoke of can certainly be regrouped with the Dremel or the side of a drill bit to provide some relief
And I hastily used type of talk and made a comment about being weak in my original post, which came out wrong but Bryce is a slight fella and I suppose it is something to be considered. It's pretty hard to imagine with that wand and a hole glide. Unless there's something wrong with his health that wasn't going on the year or two ago, which I believe he should take into consideration.
Slot and hybrid Glides would be even worse in any scenario
Check your vacuum relief valve Bryce
Bryce C
DFW
Bryce
I'll check the vacuum relief next time I run the tm, on Monday.
Why would this cause lockdown? Is there that much more fluff to that type of padding? Or does it form a seal while other types of padding are more breathable?
Bryce C
DFW
Bryce
Thanks for the tips. I think I am in good health, I feel fine. I don't smoke, or drink, or do any drugs, and eat only whole foods.
This is a rare phenomenon, experiencing this lockdown, which I know it is lockdown as it is leaving the carpet fibers noticeably wetter.
I have the best truckmount ever bro, the CDS 4.8 😎
Dwain Ray
Frankenstein disagrees
the rubber forms a seal.
