The NEW Everest 870 reveal
Go hang out in the bird room for a couple hours you'll have a good idea of what I do..
8
870everest
K obviously—— you redirect your frustrations
Have you spoken to anyone about this??.
And what’s the bird room??
8
870everest
Reactions: Mike Draper
A few questions
  • What TM did you have prior to the 870?
  • Have you ran the 650HP side by side with the 870 to compare heat and vacuum?
  • What are you actually unhappy about heat, vacuum or both?
  • Were you under the impression that 37k was going to allow you to skip a pie slice or three?
8
870everest
A few questions
What are you actually unhappy about heat, vacuum or both?Were you under the impression that 37k was going to allow you to skip a pie slice or three?
I’ve got to be honest I really don’t want to talk about the 870 till I tweak it.. don’t want to give it bad publicity unless it’s due..$42,000 with extras not including van..
My back ground is this -
Worked on — 3 cylinder Kubota units # 5 blower on it when I was 16 years old for approximately 4 years— then then blue line # 5 blowers for multiple years— than Prochem peak - back in the day when they had hella suction- than the Everest when it was just an Everest!- than 650everest than another blue Line than hydra master 4.8 with salsa now Everest 870...... for approximately 27 years approximately 1000 jobs a year ... screw the pie drop the 🎤 have a good day........
Well then I just got to ask, you should have known better than to run that stock filter box and went straight to two and a half
something smells like sardines around here
8
870everest
Yea and if that customer would have put a mat on her carpet it wouldn’t be dirty underneath it.... sounds like your getting paid to push 870’s
Reactions: hogjowl
Does it really matter? Both are good. Lots of good options out there.
There was one guy who made his truckmount with 2 separate kohler engines. What an idiot.
Ben had a dual engine machine. It was impressive. Do you remember seeing that. It had a lot of belts churning around.
I'm not talking about Ben. I'm referring to the vacuum salesman on the east coast
Don’t know who that is. You’re the only vacuum salesman I know. I think I’m going to be on here a lot tonight. I got to sit through a Cub Scout meeting with my little guy.
