You can be whatever you want to be at industry events. Ive seen many outstanding business owners posting on the various boards over the years and met a few geniuses at the fests I’ve attended during my time in this industry.
There's a fine line between genius and idiot.You can be whatever you want to be at industry events. Ive seen many outstanding business owners posting on the various boards over the years and met a few geniuses at the fests I’ve attended during my time in this industry.
Did you mean me? LolGuilty
Having just said that, I’m thinking the actual cleaning side actually IS just a hobby for Mikey now.
The way the vacuum system works to get truck-mount performance is that it has a 3 gallon vacuum tank that is diverted into a 50 gallon recovery tank or pumped out the front.The two one stage vacuums (parallel) get most of the CFM (320 cfm) The third motor ( a 2 stage) is maximizing the lift. (180") Also adding 40 CFM to the total vacuum system.So the total vacuum is:14 HG180" of lift350 CFM = Truckmount Performance.
Both of usDid you mean me? Lol
My secret weapon! Is wha sets me apart from others. It is an antique by manys standards. But really it is a steamgeni 16" 4 jet weighted drag wand. I.prespray then clean every carpet with a rotary extractor using emulsifier. When finished i switch to a rinse and completely rinse n dry using this. Rotary gets carpet completely clean and relatively dry. Following up with the drag wand gets the carpet residue free and very dry
I'm saving 70% of fuel because the van is only idling (not 1500 rpm's like my CDS's) and using 2/10th's of a gallon of fuel per hour. There's also a 12 volt circulation pump (brushless) in the coolant lines keeping the water hot, instead of a speed control bringing the idle up to speed up the water pump on the van's, like the CDS's.Just curious how you save 70% of fuel costs if the machine still runs off the van?
And if you are spending 4 grand a month on fuel I would assume you have a successful business model already.
What repairs will you avoid using this machine?
