HydroClean Truckmounts
You can be whatever you want to be at industry events. Ive seen many outstanding business owners posting on the various boards over the years and met a few geniuses at the fests I’ve attended during my time in this industry.
Reactions: they live
they live
Michigan
Steve
There's a fine line between genius and idiot.
Some wander back and forth.
Having just said that, I’m thinking the actual cleaning side actually IS just a hobby for Mikey now.
and here I thought that I made that very clear..
and why this unit would be near perfect for me and all the many other hobbyist/semi retired 2%r's out there.
This unit will not sell in droves due to limited water flow (2)
I had a Mytee escape for a short time. Got it with a bunch of other stuff I bought. Makes a great shop machine, lots of power but no heat. Trying to run it as a truck mount would be a nightmare. No waste tank, you have to depend on the auto pump out which can be problematic. No heat unless you add a propane or other heater. It did have a proper pressure pump capable of 800 psi on at least a 4 flow wand. 4 vac motors both in series and parallel I believe. Need 4 -115v power cords or 2-220 v power cords. Or a generator in your truck. By the time you added a waste tank, generator and propane heater, you could have bought an entry level truck mount. With this Hydro Clean, without knowing anymore about it, it seems like you are powering it from the trucks engine. Just replacing the drive system and vacuum pump with electric vac motors. Maybe provide some more specs on it. How many vac motors, what type of pump, exactly how much power does it need?
