Diesel Truckmounts - Has Time Arrived ?
Dallas, Texas USA
We are constructing a new Diesel powered truckmount.
The primary advantage will be increased fuel economy and longer engine life. HP will be in the mid-twenties, with torque equal to a 30 HP gas engine.
We expect the cost to be in the 17K area with a #4MP blower system(17" hg.) and HX system.
It will be packaged with fresh water tank, recovery tank, stainless silencers, triple reel and General pump system.
Do you think that system would have lower-cost operating advantages for your company?
P.S. We built some Diesel transmission PTO units many years ago.
John Watson
Larry, I have been out of the loop on this for years, Do new diesel enginies require some sort of cytalitic converter like gas engines in autos?
I have heard about our local busses getting sometype of exaust upgrade so there is no or very minamal harmful emmisions..
There was something on TV about diesel engines being used in coal mines and the harmful exausts were caught and disposed of in what looked like a large air in take filter.
La La Land
diesel???
Ya..i had a Perkins powered "Big Red" back in the 70's....damn thing ran for twenty years till i sold it to a guy that i "believe" is STILL running it!
Dallas, Texas USA
John;
No catalytic converters.
There have been regulations for large diesel engines to capture particulate from the exhaust.
Excessive idling is one of the concerns.
The 2-cylinder engine we are using has Electronic Fuel injection,
which eliminates most of the particulate.
Larry
Dallas, Texas USA
Randy;
We are evaluating two different Diesels.
At the moment, the Lombardini engine (25 HP) is the leading entry. They have produced over 4 million engines, so they have been time-tested.
It has lots of torque @ 2000 RPM.
Noise doesn't seem to be excessive.
Kohler recently bought the long-time Italian manufacturer and supports them thru it's nationwide service centers.
Larry
Lyman
Johnstown new york
Lyman
Is a diesel 20 % more fuel efficint then a gas engine( fuel cost). Any diesel over 1600 rpms starts to use more fuel as rpms increase more then a gas engine. Also you will need a extra tank for diesel unless truck is diesel. How about propane.......... By the way, love the powrmax.
Brian Robison said:
How noisy is that gonna be. And yes, my customers care.
Brian, gas or diesel, it's the blower that makes the lion's share of noise on a TM
Larry, what RPM does the engine run while at "operating" speed?
what RPM is the blower spinning?
Dallas, Texas USA
Gary;
Heat exchanger capability looks very similar to a 26 HP gas engine.
Larry;
Maximum fuel efficiency is slightly over 2000 RPM.
Blower will be overdriven.
Fuel efficiency should be about 30% better than a similar power gas engine.
Larry
KevinD
Binghamton,New York
Kevin Dumas
I for one would never buy one. I have never been near a diesel engine that did not stink.
But that's just me, I hate diesel fumes.
TimP
I'm starting to think propane will be the most efficient way to go cost wise. As it's about 25% less than gas and providing only 10% less output. Not to mention for burning it gives more heat which we need in TM's. I would like to see a heat exchange system fired by propane, with minimal restriction to the blower, and possibly a little giant to boost the heat. In a #5 blower set up....but it's not out there for sure.
Diesel is something I've been looking at too but the price of diesel negates any savings right now vs gas. Engine longevity is something to think about though because that could be a savings over buying multiple engines over a lifespan of a TM, and labor to instal them.
It really is hard to make a decision. But the way fuel is going up.....actually coming back down right now. But at the cost it is anyway I'm starting to think my next TM will be a slide in...fuel unknown at this point.
The Preacher
i told ya you can have mine and all the accounts for a resonable fee!!!
TimP
Reasonable???? HAAAAA
I'm not interested in buying a business that isn't being run full steam ahead. I don't find much value in trying to buy other peoples customers, I don't see how anyone can say yeah they will use you cause they used them last year???? How do I know you did a good job or didn't screw them some how????? If I was going over your way to run a business I'd start up new and run a special for a while and go up high the next year and try to do the higher end business. Just my way of seeing it.
Johnny
La-Z-Boy
Johnny
KevinD:
Diesel is a manly scent. Like a horse barn or a fresh-caught bass.
Walt
If you run b5 biodiesel it wont smell nearly as bad. And personally i would be very interested in such a machine mounted in a sprinter van.
John Watson
We had a 53 M-37 Ambulance with a Diesel powered welder mounted in it used mainly for thawing frozen pipes in Alaska, Even with the exauhst piped to the outside, the interior stunk and blackened with soot all the time.
Walt
Couldn't that be fixed by plumbing the blow by tube out of the van? Also, I believe that the new low sulfur diesel should improve the exhaust soot situation.
I wonder how the aussies handle it?
you ever been around sheep, Walt??
I thnk they have lots of sheep over there and New Zealand
diesel fumes/soot smell GOOD compared to a barn full of Bo-Peeps :mrgreen:
shoot, for that matter, diesel fumes smell better than most wet wool rugs...
...L.T.A.
pHilh
Have any of you blokes that are complaining about the smell ever owned a Steamway unit??
floorguy
Utah
Doug
why exchanger unit???
I mean if you got the fuel there, run a burner with it.. let that engine breathe so it can run better..
it likes torque but not choke..
been running a powermatic for over 12 years, Phil.
as long as you burn K-1 kero they don't stink.
Burn diesel in it and it smokes when it fires AND stinks.
Bob Foster
Here is some additional perspective on diesel driven truckmounts. It is not all as logical and easy as it seems.
Great idea to have a low maintenance engine with its low rpm torque curve but,
Where are most people going to get service? Experience has shown that the typical small engine repair place really doesn't want to work on them.
Parts availability may be ok in many areas but very bad in others
Diesels must work to stay healthy. Very small diesels have historically been problematic for mechanical problems especially Lombardini on TMs. However B&S owning them now is of help.
The better very small diesels - those less than 25 hp such as the Isuzu or Yanmar are very good but expensive and also suffer with not having a readily accessed parts and service facility in many parts of the country (great engines).
Now if you step up to a 59 blower you can get into some interesting industrial diesels that have better service availability and better pricing. Engines like John Deere, Isuzu, Perkins, and other are well suited. These engine need to work to stay healthy too. They are unsuitable for smaller blowers because you can't keep them working enough.
Another problem with diesel engines in TMs is getting them to give up enough BTUs to adequately heat extraction water with a heat exchanger. This is why you see Vortex and Aerotech grabbing heat from the exhaust and other esoteric heat recovery methods.
rhyde
Portland, Oregon
rhyde
Biodiesel has higher soot content than ULDS diesel the “new” diesel vehicles with particulate filter traps cannot use Biodiesel over 10% including the sprinter and dodge Cummins without cloging the filters .
steve frasier said:
I have been running B5 low sulfer diesel and the truck seems to get better gas mileage and runs better and doesn't smell
I’ve been running b-20 in my dodge and the vortex IMO both run better on biodiesel mix and get a little better MPG than regular or ULSD diesel better lubrication and much less injector clatter. The first 2 filter I changed in my dodge after i switched to B-20 where black as a lump of coal the card lock pump I use has a filter system so now when I changed filters in the dodge and the UD they looked brand new.
Jim Bethel
Sunshine Coast, QLD, Australia
Jim Bethel
Larry, Larry Larry! We are two different countries.
Aussies = Australian's.
Kiwis = New Zealander's.
That's like me saying "I hear that all Americans carry guns. Well that is at least what I seen last time I visited Ottawa" :lol:
Jim
