Damon. When are you gonna check the temp on your CAT. I still think that glowing on your machine is an early warning sign.
  • Wow
Reactions: Nomad74
Cranked it up. put it under full load this time at full rpm. Exhaust manifold started glowing. The surface temperature of the engine block under the manifold was 285-300+
And the surface temp of the block on the other side was 175-190F. Keep in mind the fan is blowing air on that side, but that's a big difference.
Should I be concerned about that hot temp on the engine block on the side of the exhaust manifold?
This engine runs much hotter than my everest. So I think I'll start changing the oil every 50hrs instead of 100hrs
Matt, have you ever been diagnosed with OCD?
Does this look dirty to you guys? I wasn’t able to test it where it’s located at
Wtf do you have the fuel rail off now? Did you at least volt/ohm test them? Listen to see if one was acting up?
What’s another 500 I guess
I'm just reading anything that might cause the glow if it's lean fuel burning. I picked up another set for $75. Amazon product
I pulled one out of the fuel rail and noticed some debris inside the rail where it plugs in.
It’s just st as likely your cat isn’t as clear as you think but do you have any idea what EGTs are supposed to be?
Are you getting any lean codes? Any injector codes?
I haven't checked any codes. The whole inside of the CAT is cleared out. It's a big open tube now. I'll see if I can find the specific EGT
The only two things that haven't been replaced to cause this would be timing and fuel injectors. I wanted to test the injectors. But for $75, it seemed a good idea to just replace them. Remember the previous owner used transmission hoses for fuel lines. I was wondering if there was some debris that might've clogged the injectors
Good gawd Smatty......... Reminder to never sell Matt anything.. Holy jeebus, worse than a woman.. :lol:
Then you'll complain that the injectors are not OEM.. :eekk:
Dwain Ray
I use this to clean and check spray on injectors. I bought mine on ebay for 10.00 but you can find um on Amazon too
Screenshot_20230305_201938_Amazon Shopping.jpg Screenshot_20230305_202414_eBay.jpg Screenshot_20230305_202427_eBay.jpg
can you video what "this" is?
