- Joined
- Apr 17, 2009
- Messages
- 10,260
- Name
- Kenny Hayes
More than 3 hrs, but still.
3 pads for 670 seats? You porty guys amuse meOr you could use your pad machine. 3 pads and a half gallon of juice. If you go that route, please take some video.
At 2am?Dryslurry/Stairwand.
What, that’s only 225 per pad3 pads for 670 seats? You porty guys amuse me
I'm having a comfortable retirement, partially due to dragging a porty around and partially due to my wife's money management skills. Of course, if you would like to add to my retirement fund......3 pads for 670 seats? You porty guys amuse me
I could just clean em with a micro and forget the pad, would that make you feel better?![]()
Did you use a porty because it was so cold in your area or were you in giant buildings all the time where a tm wouldn’t work?I'm having a comfortable retirement, partially due to dragging a porty around and partially due to my wife's money management skills. Of course, if you would like to add to my retirement fund......
Mostly high rise apartments and secure buildings. My porty was rigged pretty good, dual parallel vacs, 3500 watt heating system set at 240 max,500 psi pump. Vancouver doesn't get cold very often. I lost maybe 5 jobs because I didn't have a TM over 40 some odd years.Did you use a porty because it was so cold in your area or were you in giant buildings all the time where a tm wouldn’t work?
Extraction is the ONLY WAY TO GO…
And gave them to me.Mostly high rise apartments and secure buildings. My porty was rigged pretty good, dual parallel vacs, 3500 watt heating system set at 240 max,500 psi pump. Vancouver doesn't get cold very often. I lost maybe 5 jobs because I didn't have a TM over 40 some odd years.
Theater seats are not normal residential fabric. Certainly not the old type. There is therefore no condemnation![]()
Or…. You can believe that you’re not a hack and make comments on a bunch of shiet that you don’t even do.certainly for any "normal/regular" upl fabric
But we must realize, we have janitors and hacks here too
fortunately for them, you can be a hack in this biz and still make good money
plus, ago.
How the heck would I know? I’m a money making hack.2011 is when I shut down the truck
has there been any "revolutionary" juices or technology since then?
