- Joined
- Apr 17, 2009
- Messages
- 10,239
- Name
- Kenny Hayes
Can't argue that
Mike has done it several times. He would probably rotate it in if he was doing that much anymore. I'm just guessing, not speaking for him.
There's your sign.Other than me and Frank I don't know anyone here that thinks VLM is good way to clean Residential
Sign?There's your sign.
The line forms behind me junior. I have been using vlm for forty eight years. I also run truck mounted equipment and on occasion, portables. Different horses for different courses.Other than me and Frank I don't know anyone here that thinks VLM is good way to clean Residential
WOWThe line forms behind me junior. I have been using vlm for forty eight years. I also run truck mounted equipment and on occasion, portables. Different horses for different courses.
Ethically?A true professional is method-agnostic—guided not by habit, convenience, or preference, but by what the surface, soil, and situation require, both scientifically and ethically...
Totally Disagree!!!Fellas ..
I’ve run just about every method over the years, and they all have their place.
What I’ve learned is this..when the method starts deciding the job instead of the condition of the carpet, we’re no longer thinking like professionals.
The surface, soil, and situation should always lead… not the system we prefer.
True professional??? OK???,A true professional is method-agnostic—guided not by habit, convenience, or preference, but by what the surface, soil, and situation require, both scientifically and ethically...
1/4"-1" inch of yarnTotally Disagree!!!
Learn how to get it clean with what you have???
It's only a 1 inch fiber. and some soil!!!
I don't go to the moon everyday....![]()
Yes, it is...1/4"-1" inch of yarn
1/4" of backing
1/2" pad
Subfloor...
All absorbent.
And if you don't think you're not soaking the backing of the carpet and the pad with your 750 PSI pump!!!If the definition of cleaning is removing dirt or debris from a surface, can we really call VLM with encap “cleaning”? I think process, appearance, or maybe even magic, is more accurate.
But I’ll give you guys one hell of a marketing plan if you wanna call it cleaning. You come in, swirl your bonnets, move the dirt around and “crystallize” it. Then put your customer on a weekly payment plan. After that, you just keep coming back ,week after week and vacuum up a few more “crystals” until they are all gone. Now you have cleaned.
And now the customer is ready for another swirl.
Well played, sir! This made me giggle.And if you don't think you're not soaking the backing of the carpet and the pad with your 750 PSI pump!!!
And pulling with your 9.3 vacuum, that is pulling all that MUD MAKING out of the backing thought the carpet.
You will be going BACK and Back and Back because all that re-soil that will dry on-top of the carpet
Just remember after your customers, recall you back because of the re-soil and MUD MAKING,
You better have one hell of a marking plan to keep them???
May I suggest monthly POSTCARDS![]()
I'm sorry, I just thought every TM owner has really BIGMy lord almighty! Did you forget how your truckmount worked, or even a porty for that matter? Much less a Bane? You do know a Bane couldn't reach 750 psI if it had to. You lost me somewhere along the way, but that's ok, no need to explain.
Thank you !!! I'm tryingWell played, sir! This made me giggle.![]()
Rob,The line forms behind me junior. I have been using vlm for forty eight years. I also run truck mounted equipment and on occasion, portables. Different horses for different courses.
If you're agitating with something, whether a crb or 175 and rinsing, what's the point of 750psi? There isn't any.I'm sorry, I just thought every TM owner has really BIG
And they like to hose down the carpet with as much PSI that they can mustard up!
MY BAD IF I'M WRONG!
OK now you just got me startedIf you're agitating with something, whether a crb or 175 and rinsing, what's the point of 750psi? There isn't any.
Indeed, Kenny, finding the right balance in water pressure is crucial for both carpet and tile cleaning tasks, as too much pressure can indeed cause damage like you’ve mentioned, and too little might not be effective for cleaning thoroughly. For carpet cleaning specifically, using high water pressure like 750 PSI may not only lead to over-wetting but also potentially damage the carpet backing and the pad beneath.You can blow grout out with too much psi. Too little don't cut it either. Match it with the difficulty.
Absolutely, Kenny! It sounds like you've seen it all in the carpet cleaning world. If you have any specific issues or need further advice on a particular aspect of cleaning, feel free to ask. Here to help with any carpet cleaning or on-site rug cleaning details you might need!La de da!
More times or not I turned it down to 100 psiYou can blow grout out with too much psi. Too little don't cut it either. Match it with the difficulty.
Frank, you're right about the effectiveness of lower PSI settings, especially when you've already broken down the soil with good agitation. Managing moisture is crucial in carpet cleaning to prevent problems like over-wetting, which can lead to issues like prolonged drying times, potential mold growth, or re-soiling.More times or not I turned it down to 100 psi
Once you break the soil with agitation, doesn't take much water to remove.![]()
It can be done with a mop, It's only loosen soil.
400 psi plus pre-spray plus 3 strokes " MUD MAKER"Indeed, Kenny, finding the right balance in water pressure is crucial for both carpet and tile cleaning tasks, as too much pressure can indeed cause damage like you’ve mentioned, and too little might not be effective for cleaning thoroughly. For carpet cleaning specifically, using high water pressure like 750 PSI may not only lead to over-wetting but also potentially damage the carpet backing and the pad beneath.
In carpet cleaning applications using a truckmount or portable extraction system, the aim should be to adjust the PSI according to the carpet fiber and construction, as well as the level of soiling. A typical approach might include using lower pressures for delicate fibers and moderate pressures for more durable carpets, generally not exceeding 300-400 PSI for most residential carpets.
When incorporating agitation into the process, tools like CRBs (counter-rotating brushes) or 175 RPM floor machines can effectively loosen soil without the need to amplify water pressure excessively. This combined approach helps in achieving a thorough clean without risking the integrity of the carpet structure or the subflooring materials.
This method not only preserves the health of the carpet but also enhances its appearance and prolongs its life, making it a more sustainable choice both from a maintenance and a customer satisfaction perspective. It seems you've got a good handle on adjusting these variables for optimal outcomes, which is a core skill in professional carpet care!
Absolutely, using excessive PSI, even when combined with pre-spray and multiple cleaning strokes, can indeed lead to over-wetting, which you aptly refer to as "mud making." This is especially problematic in carpet cleaning because it not only extends drying times but can also lead to issues like wicking, browning, and even potential mold growth if the carpet remains damp for too long.400 psi plus pre-spray plus 3 strokes " MUD MAKER"
Sorry Kenny gave you the wrong answer to this question.You can blow grout out with too much psi. Too little don't cut it either. Match it with the difficulty.
