Rob Grady
- Joined
- Jan 31, 2016
- Messages
- 636
- Name
- Rob Grady
Yes, I posted that pic several years ago.Did you clean that job before?
I use the he RVjr almost exclusively, although I will use my aw29 with your glide from time to time.Would you mind walking us through your entire process?
how long does it take you to clean an average size 12X12 room?I use the he RVjr almost exclusively, although I will use my aw29 with your glide from time to time.
This job wasn’t much different than any other. Pre vacuum, hyroforce application of our Roto-Static Magic, and go to town. No extra boost from any other cleaning agent.
I have several interchangeable cleaning heads that are choked down to 1 jet each, in .5 .75 . 1.0 up tp 1.5 .Most of the time I stay with the .5 and set psi around 150-200. Clean 100sf fully valves. Turn of valve and go over the entire area again vacuum only.
I eliminated the trigger and use a on/off valve for solution control coupled wit a needle valve on my lead line to fine tune the process.
I meant were you the one who cleaned it the time before the pic was takenYes, I posted that pic several years ago.
About 1/2 hourhow long does it take you to clean an average size 12X12 room?
