Wine stain in Travertine
Ray Burnfield
Ray Burnfield
We came across this at a high end hotel. We're not sure what they tried before to take it out.
We tried a poultice and it didn't do anything.
Any other ideas?
Cameron DeMille
cameron demille
that's limestone and it's probably set in there really well.
what poultice did you try? There are a dozen or more popular formulations and you need to use the right one. Natural tannins like wine, coffee, leaves, etc. require a fairly strong hydrogen peroxide mix. 40 volume from hair salon supply stores, i think 6-9% HP. If you do it correctly, it will come out.
You can try bleach and warm water, NOT as a poultice, but agitate it and let it sit for a bit. start with 50/50
Reactions: Ray Burnfield
J Scott W
Jeffrey Scott Warrington
I have removed wine from travertine using a large dose of StainZONE (which is an oxidizer that includes peroxide) and then covering with a poultice.
Cameron DeMille
cameron demille
I don't know what the proper term is, but it basically is a chemical burn. It happens with various chemicals to certain stones. It gets chalky and white. Depending on the stone, it can be fixed most of the time.
GeneMiller
gene miller
you have to be careful when you throw out "bleach". Bleach by itself, sitting there long enough will damage the stone.
I would always start light and watch it closely. I never knew it would hurt the stone.
Gene
