- Joined
- Oct 6, 2006
- Messages
- 117,396
So I don't know. He comes across as mildly intelligent to me, for a janitor anyways.Raser Hayes
Kenny is a long time business owner and family man that even has a family member or two working in his organizationHe must have bought something from you
Nada.He must have bought something from you
Jackass!Nada.
I take that back. He bought something used a wand, tile tool or marital aid... I forget
20 years ago,…A wand in a box![]()
It wasnt an OP machine, unfortunatelyJackass!![]()
I've left footprints as well using Tsunami. Needs to be acid rinsed to prevent that in my limited opinion.Not only did I misdiagnose this floor from the photograph that I posted elsewhere. I also blew it in the freakfact that my Crocs left footprints after using Sager tsunami and sugar oxy end cap to chemically etch the floor, normally I would have used 40 volume but I removed it as I'm headed to Vegas on Saturday and the only peroxide base product I had was the oxy encap, while it worked well, there were some kind of weird chemical reaction with my favorite casual footwear
You are correct sir and I should have ran an acid rinse but my travertine etch prevention intuition wasn't working well today.I've left footprints as well using Tsunami. Needs to be acid rinsed to prevent that in my limited opinion.
Should have said, my experience, as I don't do a lot of hard surface floors.Wisdom
Your opinion is limitless
We all have days like that. At least John f..k up hasn't called me today.You are correct sir and I should have ran an acid rinse but my travertine etch prevention intuition wasn't working well today.
That happened to me before with some tennis shoes. Went to shoe coverings which solved the problem. Also good for giving estimates. They have a tread on the bottom and last forever.Not only did I misdiagnose this floor from the photograph that I posted elsewhere. I also blew it in the freakfact that my Crocs left footprints after using Sager tsunami and sugar oxy end cap to chemically etch the floor, normally I would have used 40 volume but I removed it as I'm headed to Vegas on Saturday and the only peroxide base product I had was the oxy encap, while it worked well, there were some kind of weird chemical reaction with my favorite casual footwear
do they make them in shrek sizes?That happened to me before with some tennis shoes. Went to shoe coverings which solved the problem. Also good for giving estimates. They have a tread on the bottom and last forever.
