Which porti is best to run a T/G spinner
M
Mardie
I am looking to purchase a porti for a T/G spinner.Thinking rotovac or US Product's flood pumper? Will also need a booster pump to come from the tap.Any recommendations will be appreciated. Will a porti produce enough suction to get it dry? Will a porti be much slower than a T/M? I will also be using this for small flood work.
Thank's
Larry that's 500 psi, will that compare in cleaning ability to the 1200 psi unit? Or does that unit offer an upgraded pump?
We quit using the Butlers at 800 psi and use the PC units since they can handle the 1000psi plus and they clean better and faster.
