- Joined
- Oct 6, 2006
- Messages
- 117,380
And why?
Jim Nazarian said:Very happy with the 7qt non adjustable Spraymaster, if you use powders periodically clean the filter.
meAt said:electric
Battery Multi-Sprayer and corded 3gal HF electric
why?
Cause they're reliable and we know exactly what our dilution rate is.
I've owned 2 HF in-line
adjustable and non.
they're unreliable, inconsistent JUNK PIECES OF SHEET.
Fussy/INCONSISTENT about heat, psi and chem viscosity
and that's WHEN they work.....JUNK!!!!!
Too, they're just about as inefficient as it gets for a single wand 2 man crew.
We have to STOP the wand to pre-spray??? with TWO man crew?? (OMFG)
Not to mention, we have to run out to the van, turn down the heat, bleed off hot water just to get the JUNK POS to meter any chem???
The we "guess" if it's metering right, "this" time??
EFF THAT!!!
Put an 06 flow tip in an electric sprayer and it's not far behind an in-line volume @350 to 450psi.
I've done the "bucket test" on our Multi-Sprayer.
It puts out 1 gal of solution in 70 seconds w/06 tip
oh yea, don't tell me about dragging in ANOTHER sol line to use AND wrap up, as well McGyvering some cold water flow QD to the TM to get that POS JUNK in-line to work.
It's less hassle to use an electric that we KNOW what dilution we're spraying down
