Waste Tank (65 gal)
Spurlington
Spurlino
Im looking for a 65 gallon waste tank. Used in good condition would be good.
GeneMiller
gene miller
Have you looked into the mytee plastic tanks.
Jack Zipper Zerkie
jack zerkie
Check Cobb supply they have the roto tanks , I have them and there great. jz.
Spurlington
Spurlino
I did look at those but not too sure .. havent heard much about them. For some reason I have it in my mind that all those chambers will cause vacuum resistance. (flow interruptions) Im probably wrong. I do like the Cleaning Technologies tank. It has the drainage slope shelf and a 5 gal fresh water built right in the vac tank. But I was hoping for gently used. 36 x 36 x 12 would be ideal.
Recovery Tank 65 Gallon (Assembled & Plumbed)
"Heavy alluminum build with exclusive angled bottom."
Mounting Tabs Dimensions (floor space): 38" long X 15" wide
Tank Dimensions: 36" long X 12" wide X 36-1/2" high
$ 1387.00 Back
* 5 Gallon Water Supply Reservoir
* Supply Water Shut-off Float Valve ST8
* Recovery Filter "Flow Ezy"
* Electric Float Shut-off Switch
* Recovery Filter Bag
* Tank Gasket
* Single Wand Connection
Spurlington
Spurlino
Any thoughts on whether this would be a good idea or not - to spray line the bottom of a brand new waste tank and up a foot. The only thing I can think of is it dissolving with certain products - of course solvents. And maybe a collection of hair - what ever gets through the first filter. Or are there any other ideas out there to protect the tank from future pinhole leaks. Am I over thinking this? Probably !!
Doug Cox
Doug Cox
Where are you from? I have a SS Powerclean Tank I would sell but I'm not shipping it. It's 110 gal.
Spurlington
Spurlino
Im 12 hours East of you .. 110 is bigger than I want. I have a 20HP with 3006 Tuthill. They say a smaller tank paired with a smaller blower produces the best scenario for maximum suction. If I had a number 4 or 45, Id consider the larger tank. Thanks anyway !!
