Was there ever an uglier truckmount
chokadilas
ARTUR
Kubota 972
Roots 56
Jabsco APO
CAT Pressure Pump
Is it possible to buy from SS directly if I am not a franchise holder?
Do you know what Jabsco pump out do they use? And where I can buy it?
chokadilas
ARTUR
Can anyone recognize what model Jabsco APO and CAT HPP do they use?
The first photo of my unit without these parts, the other one is photo made by one of the member on this forum. The pump that came with my unit doesn't fit here. They throw in another pump and took the original one for some reason. Thanks!
Ugliest mount I ever saw was at a Nashville Mikefest
Oxleys rattle mount
The engine was mounted on top of the waste tank and looked like a bobble head flapping around
He cornered me as i got outside...
And dragged me over to see it....
Then he SED.."well what do you think "
I stammered back...very interesting and
Escaped as quickly as i could...
Reactions: KevinL
Numero Uno
Caesar
The Badger was pretty fugly.Then again in the seventies.You got what they made,not alot of custom anything...
D Luke
Derek
I agree overall presentation is important
which is why even though a 1 man band on the carpet side I wear a logo'd polo
but even the board favourite is one ugly machine..
but hey it rides in a 70's styled van so it doesn't look out of place
Those who know, know that that is the most beautiful piece of equipment ever introduced to our wretched industry.
Steve Lawrence
Steve Lawrence
The price also makes them more attractive..... (that’s out the door with wand, stair tool, 2 upholstery tools, rotary tile tool, gekko tile tool, steam lines, vac hoses, air mover, everything..) obviously truck as well
About 20k less than a Butler! (plus you don't get all those extras either!) What size blower on that Stanley?
Welding companies put the propane version of those kubotas in a concealed container like that also. I know it's a liquid cooled engine, but isn't some air flow better than none?
The radiator/fan side that faces the wheel well is open
edit
CJ-FL
CK-FL
They open doors while cleaning.
Nope... doors are “supposed” to stay shut during cleaning. Under the kubota’s motor mount is a hole cut in the floor approximately 24” x 24”. There are also vents on the side of the truck directly in front of the radiator and electric fan to draw air in. The hot air should be vented out the bottom.
What’s the average time on the hour meter when you retire your truckmount?
Jack Zipper Zerkie
jack zerkie
Do you know the RPM that they run while cleaning and what is the water temp when cleaning?. JZ.
Doug Cox
Doug Cox
I realize that your talking about new TMs but every time I go to Jon Don or Interlink to have work done, I stroll through the garage and no cr*p, theres always a van that looks like a bomb went off inside of it. Maybe next time I will take a picture.....
I think I saw the same vans there when I had my new machine installed. Serious POS’s
