WAR OF THE WORLD OF TRUCKMOUNTS !!!!
4]http://www.youtube.com/watch?v=fSNJsx6_a4Q4]
JUDSON TRUCKMOUNTS NOW EQUIPPED WITH MARTIAN COBRA HEAT RAY !!!!
FB7777
Hey Les,
How many gallons will that Stainless waste tank hold before it shuts off? DO you have different options for a larger waste or Aux if needed ? and what size?
Thanks
Fred
Askal
RIP
Paulsen
Al
That looks just swell Les. Nice looking welds and no paint to peel. I like the fact for safety concerns that the fuel line is not pressurized with a fuel pump from under the truck. If it springs a leak it just sucks air. Never had one leak but a plus none the less. Now we have to get the van ready by Tuesday.
Al
Jimbo
Nice work, Les and Team!
Let us know your impressions when it goes into service, Al.
adamh
Nampa Idaho
Adam Hale
Everything looks really nice but the exhaust messing my wonderfull hair up has got to go.
Make a #5 blowered one and I will get one next year.
Ann Arbor
Steve Lawrence
Looks nice!
Are those 2.5" vac nipples?
Is there any kind of filter basket or bag? How do you get to it?
Thanks,
Steve
Only problem with a Roots 56 or similar, is you wouldn't notice any change in vacuum.....but it would allow runnig the blower slower, and having a lower pitch for the same CFM....oh an cost more...but...it's all about Marketing right?
500 cfm is 500 cfm.
tmdry
DC
Bill Martins
Can these TM's be built for hard surface cleaning?
Tile cleaning w/ heat in the 1200-1800 range.
That would be a nice setup.
Would be nice to know.
tmdry
DC
Bill Martins
Mikey have you tested your pail w/ a turbo w/out scrubbing the grout lines w/ a grout brush?
Letting the alki dwell for 20-30 mins, going over w/ the turbo.
That's what I was referring to as far as sustaining heat at 1200-1800psi.
sorry dude, I'm not a grout hack.
I think (most) grout should be scrubbed.
Ive done too many to see the diff when not.
at 06 gph the Pail will melt your pecker off.
joeynbgky
Bowling Green
Joey
I havn't tried yet but........... its hard to get loans for this stuff now. i payed cash for my last tm... so i think you should start doin buy here pay here for your tm's..... ok?
tmdry
DC
Bill Martins
LOL
It's not about being a grout hack, i scrub all my grout lines since I don't have a machine that can sustain heat at those psi's in order to make the job more efficient. The guys who have the CFI/Master's Touch/Powerclean units will clean grout at those psi's if it's not super dirty w/out needing to scrub the grout lines. Doesn't work in every situation, but it doesn't mean they're a hack either.
Every situation is diff, but our "super clean" homes that only need scrubbing by the major areas of high traffic won't need a hard bristle grout bush on every inch of grout.
If you think there won't be much of a difference using the pail c4 vs a TM w/ a cat5 pump, than i'm fine w/ that.
Ron Werner
Ron Werner
Thats a sweet unit Les.
Makes me want to keep trading up :)
The two boxes behind the pump,
one is a riser from the vac tank to the blower? I take it there is still no filter there?
The other is a mix tank for solution??
Is the heat from 4ht for this unit?
If you have 230+ heat avail. Why would you need 1200-1800 psi?
That's just a grout blow out waiting to happen.
There are some jobs I would be afraid to use over 800psi on, better to agitate, dwell and take your time with 800psi than risk blow out....and you'll prob. STILL get some blow out on the worst of them.
All Spinners I've ever seen use 05 02 jets, you don't really need more flow for tile work....concrete is a different animal.
Shane T
Waukesha, WI
Shane Tiegs
Sweeeeeeeeet!
Does it really take 35 hrspwr to turn that machine?
In the pic that shows the rear I see what looks like a 2" port. What's that for? Forget it, I see in another post that its the relief valve.
In the world of the average cleaner, there are times when tile jobs come about that need to be able to be profitably cleaned on a limited budget. In those cases, the ability to clean them by dwell time and pressure rinse is of considerable importance. That being said, I have never had to go above 1200 psi to get the job done in those situations.
By the way Les, that is a much better looking unit than the fugly one Mikey has. Let me say that is a unit I could spend my money on.
La La Land
yes but could you start it up...
may be the appropriate question!!!
