Two wands for every truck
I move to the interior and retire but I'm still collecting stuff.🙄 I'm more than surprised at how well the little Mytee works at 200 psi with a single 6.6 vac motor. The internal heater will burn your paws in a second, but like all Mytee products, it needed an electrical overhaul.
I was just as surprised by my little brand new 25 year old Aquafresh. Vacuum is incredible for a single cord machine. I have a newer edic with new vac motors but still not as powerful. Only a 120 psi pump but seems to have more gpm than my newer pumps. Has a better impact on the carpet than my 220 psi pump. Probably just better made back then. It's become my go to machine for small porty jobs.
Here are a couple.
Machine is lightweight and the handle folds down. 10 gallon capacity. 2-2 stage vac motors. You can feel the wand sucking down on the carpet. Need more power? Bring out the crb.
Reactions: Living The Dream
That's looks like a usa or timbukktoo.
Definitely looks like a 100 psi pump and two 2 stages in parallel.
From back in the day.
EDIC before they went to plastic. 2-2stage vac motors in series. 120 psi pump.
sassyotto
Paul
two wands? Just cause you have two doesnt mean everyone needs them.
Heck, I carry two CRBs on board. A HOST machine and a Brush Pro 17. I like the HOST machine for small jobs, rugs (because its lightweight) getting in tight spaces and obviously for steps. Everything else I use the Brush Pro. Its not for everyone, but it works for me.
