Time for a new float?
Trip Moses
IMOL
Trip Moses
  • Wow
Reactions: Nomad74
I hate when that happens. Because of all the sloshing around it plays hell with you shut off. We put in an overflow tube using stick radiator hose. A few simple fitting and most of it will drop through the floor warning you.
Trip Moses
IMOL
Trip Moses
I’ll do that
KevinD
Kevin Dumas
I clean my truck out about once a month on average.
Trip Moses
IMOL
Trip Moses
The manufacturer neglected to tell you that that is the self cleaning option that comes with those tanks at no additional charge.
At least 10 gallons of water poured out when I opened the drivers door
Jim Williams
Jim Williams
Mine did that this week and it only needed a little adjustment. The float was going too far down when the tank was empty and was getting hung up and wouldn't pop back up when I filled the tank. There was an easy adjustment bolt on the arm of the float that took care of it.
I had the issue last week. I use a dema float. Very reliable but when they go, they just go. I like the idea of an overflow hose. Keeps it out of the van at least.
Reactions: Trip Moses
Check the rubber nipple on the plunger too. They are a wear item and need replaced periodically.
KevinD
Kevin Dumas
How long is the float rod and float.
The shorter the better.
