Tile cleaning results
boazcan
Tampa Bay/Central Florida
Bryan C
I would like that one for a brag book. Nice.
The edges do still look dirty from where the spinner couldn't get. Did you get those by hand to make them match? Do the "turbo tilt".
George Valliant
Calavares County Jumping Frog Jubilee!
The hillbilly knows how to clean some tile n grout!
Was that located near the cement pond or the indoor outhouse?
Hehehe!!! Grin
Just giving you some chit Chris!
I used to run up n down them hills a lot when living in Modesto.
Would have married a chic from Big Trees but.....
Yes we had to do some hand work due to the muddy mop water being pushed wall to wall. Turbo will not tilt.
floorguy said:
what did the custy say???
LOVED IT and was blown away. He had never seen the true color of tile or grout.
George Valliant
Edges are a pain.
I usually like to run the Gekko edge tool around the perimeter before blasting with the spinner.
I've been playing around w a couple different tile and grout cleaners.
I like the Cobb Powermaxx but was very impressed w the Judson O2 last couple times out.
What cleaner did you use?
Looks nice...
Blue Monarch
Lincoln, NE
Dirk Wingrove
Definition:
Turbo Tilt = Lift one side of it and spray the bejeezus out of the wall and edge of the grout.
Works like a champ. Do it and never look back.
Fort Worth , Texas
does that relief valve work better than the plastic one on the new TH?
by the way good job. we always hit the sides by hand on the nasties.
TimP
Use your tile brush against the baseboard and scrub the lines accross the tile the best you can then lift the turbo and spray it out and suck it up. It by far is the quickest and best way to get the base. If the customer has gotten the tile filthy on the edge then they have already gotten the base just as wet as you will.
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Good job Chris!
That almost looks like its an American Eagle brand(or Eagle something). They went out of business about 2 years ago and use to sell a spinner-like tool.
