- Joined
- Oct 6, 2006
- Messages
- 117,341
so much wrong going on, yet it's the norm.
Somewhere in the comment section, I bet there is a post saying “where the glide?”Y’all are harsh!He could at least corn roll it
Did you send him an invite to join TWGCCF?so much wrong going on, yet it's the norm.
I would imagine that is considered pristine in your neck of the woodsWTH is that solution hose duct taped to the vac hose
Mikey's just mad he's making it look pristine without a glide
I have no idea how you 98%'rs thinkYou are assuming he started at the door, and would be wrong.
He choice of direction for the doorway and behind the door is ideal for the first 2 cleanings- then followed up with working the way out the room.
I noticed he had "cleaned" the other part of the room 1st. But would have used a 360iBH instead.
OMGI think he is doing fine
No, he's not.Honestly besides flooding the carpet on the backstroke and awkward cleaning angles fighting the hose while cleaning and lack of efficiency I think he is doing better than most.
He is in a uniform he has a walk off blanket and a cool pocket for his spotter to hang from
I’m just trying to stir the potIf it was pre-sprayed, not sure, it should have been scrubbed in and most of those spots would have been broken loose.
His wand technique is crude and will cause overlap wicking.
I think he may be hooked up to the kitchen sink faucet..
Glide or no glide![]()
I didn't say he was perfect.I have no idea how you 98%'rs think
Tap water..I see no steam emanating from the wand!
I wonder if he thinks man these guys spend 75k $$$$$ to do this and I am doing it with 500$ InvestedTap water..
Of course he does.I wonder if he thinks man these guys spend 75k $$$$$ to do this and I am doing it with 500$ Invested![]()
