Spinner turning slow
Andy
Doesn't Matter
I have a Hydro-force SX-7 that is turning slow, What causes that? and Can it be fixed? If so how do I fix it?
Using 1200 psi and 0502 jets. Other spinners that I have work fine.
Jack Zipper Zerkie
jack zerkie
Yes the jets must be even and in a straight line as 9&3 on a clock if not the pressure will not push the rotation of the spinner bar. jz.
Reactions: Mike Pailliotet
Andy
Doesn't Matter
Jets are in line with the bar. I can't do anything about the angle.
dealtimeman
Everyday is Saturday.
Michael
Check your inline filter and check you jets to make sure they aren't clogged.
Also spin the bar by hand it should go around a few times without stopping if you spin it and it just stops with out a full turn your bearing is probably shot and need a new one.
