- Joined
- Oct 9, 2006
- Messages
- 6,281
- Name
- John Olson
I was talking to someone about tile and grout cleaning and they asked me to compile a short list of basic rules that could use to not screw up. Here is what I came up with off the top of my head. Tell me what you think?
Here are the rules ?
1., Identify- You need to know if it is a natural or man made tile and if it has wax or sealer.
-to identify if it is natural stone you put a small dot of your acid cleaner (carried in a 4oz flip top bottle) in a inconspicuous
area. If it bubbles then it is a natural stone and you do NOT want to use any sort of acid cleaner on it. There is one exception and that is SOME form of Slate that are acid Insensitive but to be safe treat slate as any other natural stone until you are 100% confident.
-To test for wax put a small dot of your stripper (carried in a 4oz flip top bottle) in an inconspicuous area. Let is sit for 5 minutes or so while you inspect the floor. If there is wax present it will turn goey and sticky.
2. NEVER use acid cleaners on natural stone only alkaline (see above for the ONLY exception to this rule)
3. Alkaline is safe on all floors
4. Always ask if Mop and Glow has ever been used on the floor. If yes RUN AWAY FAST! (Exception to this rule is charge $9 per sq ft) search mop and glow on dirtygrout.com
5. If there is wax on the floor charge double your normal rate. It can be taken off but it is a HUGE pain.
6. NEVER put wax back on a floor you just removed it from unless it is VCT and you where actually getting paid to strip and wax VCT. ?
7. ALWAYS map the floor plan and mark any missing, chipped, cracked tiles and any separated, cracked, missing grout.
8. ALWAYS mask off stainless steel appliances.
9. ALWAYS mask off baseboards making sure that little to no water can seep under them. MDF Baseboards will pop and swell QUICK and there is no fixing only replacing.
10. Everything you tell your customer before you start is education, everything you tell them after is an excuse ?
Any others?
