- Joined
- Mar 24, 2009
- Messages
- 3,547
- Name
- gene miller
Set my sprayer down and the rubber left a ring. It has happened before but you just wipe it up. This time it was on marble. Not the first time on marble either but this time the ring would not just wipe off. It definitely seemed to penetrate and almost etch it. When I was done removing it I could still see the faint ring left behind. The marble was a polished Arabescato Carrara. For those who are thinking there was an acid on the bottom of the sprayer there wasn't. The only thing in that sprayer ever has been flex boosted with peroxide. Also I don't clean with acids. I have a similar ring on my granite counter top from when they used rubber suction cups to pull it together. They never could remove it. Does rubber react with certain stones ?
Gene
Gene
