real world views on prochem new acid rinse
Montana
Swani
for those of you that have used it, please review product. i am looking to place a order soon but i wanted to hear from the pros
I got a sample and will definitely be buying more and using it as my new rinse. Smells great, mixes great, and although it's early on in the game, I feel that it improved cleaning on the carpets that I used it on.
Reactions: rwcarpet
rwcarpet
Youngstown, Ohio
Robert Hodge
I've been using about a month. I like it. You will notice a difference in clean, especially on nastys. Great smell, and will keep your van smelling a little better, especially in the morning when you get in the van.
I mix it up in a gallon big mouth jar. Despite what it says about easy dissolving, it still needs premixed and then poured into solution tank, and tank topped off.
And yes, I will be using this as my go to solution.
Ann Arbor
Steve Lawrence
We will use it soon in our operation. My son used it for a lot of furniture cleaning at the last RMHS get together and he really liked it a lot. Made the cleaning better and has a great fragrance.
If that is a reason I will never promote THAT one nano prespray again
D Luke
MI
Derek
I've heard great things, but alas I will never get to try it due to the Butler injection not being compatible with powders. Worth it.
Reactions: Bruce Humphrey
wilpath
you know, i owned a 1994 butler brand new and back in those days, i had a lot of problems with the chemical system/
quite frankly, as good as the butler was to my company, its a shame in 2020 they havent gotten it right
wilpath
i have been with the prochem everest since 2007 and i guess i aint looking back, i am not bringing down butler, o owned once and it has been a great system for me for a lot of years,, from 1994 to 2007, its been a solid machine with few and i mean few problems, easy maintenance, belts are a breeze to change, oil change once a month , great machine, in fact , the butler system outlives the truck
wilpath
but its high time they get that chemical injection system right with powders,,, noone should be forced to use liquids only,, it should be your choice
San Francisco, CA
If you prefer to work with powders you can change the metering from the needle point one (that comes stock with the butlers) to one that tolerates powder. I had Butler do it when I bought the machine, but you or your mechanic can do it as well.
Rick J
Ohio
rick Jones
long ago ,, I had a Butler , older than any mentioned here. My system worked fine,, With tinkering sometimes.
It may have aftermarket injection system on it, I do not know. I did rebuild the injection pump one time.
D Luke
MI
Derek
I was a die hard Flex Ice user, and I would like to try the new Prochem, but the Butler Injection makes things easier and has been bullet proof for me. Also, I have no complaints whatsoever with Deep Blue.
