Prochem powered rinse
wilpath
SEND IT TO ME...... its my to go rinse, use a cordless drill with paint mixer in hot water
MA
Doug B
Dissolves bad
I agree. Wondered why my chem injection stopped working. Screen filter was clogged with the stuff. I even mixed it on the light side.
Seems to get hard once you open the jug
1/3 of a tub left. Have to scrape with the scoop a lot to loosen it up.
Shouldn't need to do that. It should be soluble.
Back to liquid acid rinse or dry slurry depending on need. Maybe it is just me, but I had the same issues with Ice.
scotty747
Had a nasty today i wanted to try dry slurry on but i left it at the house. The Prochem acid rinse i like better than the powder.
Meter Maid
The Undetective
Dayton,Ohio
I mixed a teaspoon in a glass of hot water and let it sit for a few minutes.
Easy to see the powder at the bottom of the glass.
Meter Maid
The Undetective
Dayton,Ohio
So, I’m supposed to go from pouring 32 oz in my 5 gallon jug and working, to stirring this in hot water before pouring it in my 5 gallon jug?
32 oz who the hell are you kidding
12 is more than enoughs If you got an onboard softener
You got to buy some of Larry Cobb's PowerMax
that would make his 2020 what with your ability to follow directions
So what’s the benefit of this powdered rinse then?
like most juices, price per RTU gal is a little less
also take up less room on shelves
Most rinses I’ve seen recommend 32 oz in the 5 gallon jug.
can you tell me why you think acid rinse is necessary?
can you tell any difference when you use it ?
Or do you use it 'cause "everyone says so" ?
Reactions: Meter Maid
Meter Maid
The Undetective
Dayton,Ohio
Well... I guess I was told to use a rinse.
I’ve always used a rinse, so I don’t know.
If I use a high ph product like UltraPac Extreme, shouldn’t I use an acid rinse?
Doesn’t an acid rinse help pull out soap residue from household products and shitty carpet cleaners?
Doesn’t an acid rinse help prevent wicking?
Meter Maid
The Undetective
Dayton,Ohio
You are more than just a little stupid. Do you stir your coffee when you put sugar in it?
Hold on, asshole.
I’ve been pouring 32 oz of rinse in my 5 gallon jug for a while.
Didn’t have to stir it.
What’s so great about this Prochem rinse that I should have to stir/shake it?
So, why am I stupid? I’m only looking for some guidance.
lemmie help you with mixing powders
do you have short piece of solution line?
If not, get one.
(or use your sol line)
When mixing powders, use hot water from the TM, while using the hose to stir while filling
fill your jug while bleeding off hot water at shut down.
Meter Maid
The Undetective
Dayton,Ohio
If not, get one.
That was very helpful and I thank you.
