Prochem No Pressure - Appreciate any help
drewl
Drew
Role
Years of Experience
1
Thanks in advance for the help with this!
It's been really frustrating and I'm kind of out of guesses. I basically had pressure, but it was low and was told that it might be the regulator, so I swapped the regulator out.
After swapping out the regulator, I now all of a sudden have basically no pressure. I even attempted to put the old regulator back in and still no luck. I’ve cleaned out the solution screen, check valve, pressure, balance, orifice. Bypassed the front and middle heat exchanger straight back to the water tank on the low pressure side. I can verify that the pump seems to be pumping just fine if I pull the hose coming from the pump off the regulator manifold, I get a nice steady stream, and I can also prime the chemicals just fine.
There's plenty of water, and I'm hooked up to the house, so it's consistent, and so I know that's not a problem.
Any help is very much appreciated!! Total newb BTW. I bought a used legend GT and have been learning and fixing quite a bit. Not a well maintained machine at all unfortunately…
Does your truckmount use a regulator or an unloader?
And have you checked your pressure with the same hose? You might have a bad quick release on your hose
Reactions: hogjowl
Is the pump clutch engaging? Does the pressure gauge show water pressure? how much?
drewl
Drew
Role
Years of Experience
1
I had a factory regulator and am back to using it. I tried 2 vrt3 unloaders with the check valve removed and verified that i was connected in and out correctly.
I'm not even seeing pressure on my guage. Installed a brand new gauge. Also when i pull the hose on the out port of the regulator, I get no water on that side. The lo pressure side. I can turn the pressure regulator up and down without change.
Yes, I get a steady stream of water with seemingly good pulsing pressure shoots out about 12 feet from hose end when I pull the hose coming from the pump off the regulator manifold. While the hose is off, I can turn the clutch on and off and it turns the stream on and off.
Then you have to two filters to check
drewl
Drew
Role
Years of Experience
1
Thanks for all the responses and help! I figured it out. I had my guy check the pump diaphragm and he didn't tighten it enough. It had just enough to lie and push out water good until it was under any resistance and then it would just barely do anything. Tightened it down and it's running great! On the plus side, I learned a TON and feel very comfortable fixing anything.
Find a YouTube video on your pump and be ready when it needs seals and valves.
Reactions: jessi
Just a heads up, there are times when it’s the simplest of things.
I had an issue with no output, and it turned out to be a bad quick connect. When solving any problem, do it with a process of elimination.
When I was 19, I had been on the road selling truck mounts for about a year. I studied all that I could, and went to classes that taught how to repair aircooled engines and how to diagnose and repair Cat pumps.
One night I was showing a machine (a Prochem 100 fuel fired unit) and it lost pressure.
I told the customer “don’t worry, I can fix this” and proceeded to remove the pump head so that I could clean out the check valves.
(It was around midnight after the restaurant had been closed for the night)
I got into the pump while my customer patiently waited. I have to think he was pondering the wisdom of letting this kid get him into the middle of this debacle.
I didn’t have parts, but was confident that I could find the problem.
No luck.
While his helper and him were bringing in their portables, I walked over to wrap up my hoses...
...and discovered I hadn’t hooked the machine up to the after source.
Yes, always eliminate the simple things.
No luck.
Did you get a sale?
icleancarpetz
Rafael Samson
No luck.
icleancarpetz
Rafael Samson
My fire-dragon use to put out so much heat it would cook the seals and check vavles from time to time. The smallest of a piece would wind up clogging a hose somewhere. Sometimes had the darnest of time finding which hose was clogged.
Talked to John from Johns Hot Heat Exchange when he was alive and suggested I add a diverter to divert some of the heat coming off the fire breather 28hp Kohler to better control and manage heat and keep the pump seals from cooking.
One of the best moves made was that diverter. No more cooked seals.
The tinniest of debris can cause huge headaches.
