Power outage
encapman
Rick Gelinas
OK AI what is the best encapsulation detergent on the market for commercial carpet cleaning?
Reactions: frank fratto
Pro-Helper
AI Bots
For commercial carpet cleaning using encapsulation methods, several products from our approved chemical brands are highly regarded for their effectiveness:
1. Prochem's Axiom Clean Encapsulant - This product is well-suited for commercial applications, offering a polymer technology that encapsulates soil and dries into a brittle crystal that can be vacuumed away.
2. Chemspec's EncapBrite II - It is another excellent choice for low-moisture cleaning and provides good soil encapsulation properties.
3. Hydramaster's Release with OxyBreak - This encapsulant is specially formulated to tackle both soils and staining with oxygenating power for improved cleaning.
4. Bridgepoint Systems' Encapuclean Green DS - Known for its dual surfactant system, it improves cleaning effectiveness and works well in a maintenance program.
Always consider the specific needs of the job, such as soil load and fiber type, and follow the manufacturer's guidelines for dilution and application to achieve the best results.
encapman
Rick Gelinas
Well that single-handedly proves you're not so intelligent.
encapman
Rick Gelinas
I'm here to assist with technical carpet cleaning questions and advice. If there's anything specific you need help with, please let me know!
Come on Mike. Is this some kind of a joke or what?
Pro-Helper
AI Bots
I'm here to provide information and answer questions related to carpet cleaning. If you need assistance or have any queries, feel free to reach out! I'm here to help.
Pro-Helper
AI Bots
Which is better when using vlm, pads or bonnets?
When using very low moisture (VLM) cleaning methods for carpets, both pads and bonnets have their advantages depending on the situation and the specific needs of the job. Here’s a brief overview to help you decide which might be better for your situation:
### Pads:
  • Type: Typically used are microfiber or cotton pads.
  • Benefits: Pads are generally better for absorbing soils and can be more effective on carpets with a shorter pile. Microfiber pads, particularly, are great for absorbing large amounts of soil.
  • Best for: Residential settings or lightly soiled commercial carpets.
### Bonnets:
  • Type: Usually made from cotton, rayon, or a blend, and sometimes have scrub strips.
  • Benefits: Bonnets are effective for aggressive cleaning and are good at providing friction to remove soil. They can be better for cleaning commercial carpets where there is more foot traffic and heavier soiling.
  • Considerations: Bonnet cleaning requires careful handling to avoid issues like overwetting and pile distortion.
### General Advice:
  • Soil Level: Consider how soiled the carpet is; bonnets may be better for heavier soils due to their scrubbing action.
  • Carpet Type and Pile: Low pile carpets can be effectively cleaned with either pads or bonnets, but consider the fiber type and pile height. Pad cleaning might be preferable for delicate fibers to prevent damage.
  • Frequency of Cleaning: Frequent, lighter cleanings (maintenance cleaning) are well-suited to pads, while less frequent, deeper cleanings might benefit from bonnets.
Using an approved VLM product, such as those from Prochem or Chemspec, will also influence your results, so always pair your choice of pad or bonnet with the right chemical for optimal outcomes. Remember to always pre-test in an inconspicuous area to ensure carpet fiber compatibility and colorfastness.
I'm pretty sure we're not thinking about the same kind of pads. I'm speaking of fiber pads, not microfiber or cotton pads.
Pro-Helper
AI Bots
Thank you for clarifying that you're specifically asking about fiber pads for very low moisture (VLM) cleaning. In that case, let's focus on fiber pads versus bonnets:
### Fiber Pads:
  • Material: Typically made from synthetic fibers such as polyester or nylon.
  • Benefits: Fiber pads are designed to be more abrasive than microfiber or cotton pads, providing a deeper scrub. They are effective at breaking down and absorbing soil, especially in commercial settings where carpets may be more durable.
  • Uses: Often used in commercial environments due to their durability and effectiveness in dealing with heavier soil loads.
### Bonnets:
  • Material: Usually made from cotton, rayon, or a blend, sometimes with scrubbing strips.
  • Benefits: Bonnets provide good friction and are also excellent for agitation, helping to lift soils from the carpet fibers.
  • Considerations: They need to be handled carefully to avoid over-wetting and potential distortion of the carpet pile.
### Choosing Between Fiber Pads and Bonnets:
  • Soil Level: Fiber pads are excellent for moderate to heavily soiled areas due to their abrasive nature.
  • Carpet Type and Pile: Consider whether the carpet can handle the aggressiveness of a fiber pad. For sensitive fibers, it might be safer to use a less abrasive pad or a bonnet with moderate scrubbing action.
  • Intended Results: Fiber pads can offer a more aggressive cleaning method, which can be beneficial for restorative cleaning cycles.
Also, always match the cleaning method with appropriate VLM chemicals from brands like Chemspec or Prochem for enhanced cleaning performance and to ensure compatibility with the carpet's material. Remember to test your method on an inconspicuous area of the carpet first to ensure there is no negative reaction such as dye bleeding or texture damage.
frank fratto
frank fratto
red fiber pad first, follow up with a wet baby blue microfiber pad.
with the right chemical and a 175 you can go all day.[ this goes without saying, vacuum first]
I know, yada yada yada!!!!!!!!! 😜
Pro-Helper
AI Bots
Thanks for sharing your approach, Frank. Utilizing a red fiber pad initially for more aggressive cleaning followed by a baby blue microfiber pad to pick up residual soil and moisture is indeed a practical combination in very low moisture (VLM) cleaning. The red pad offers good scrubbing power to break down heavy soiling, while the microfiber provides a finer clean and helps in drying the area effectively.
Using a 175 RPM floor machine ("a 175") can indeed allow for thorough and efficient cleaning, especially in commercial settings where extended operation is required. Pairing this method with the correct VLM chemical, chosen from quality brands like Prochem or Chemspec, can enhance the cleaning results even further.
Just to reiterate, as you mentioned, the importance of vacuuming before starting the VLM process cannot be overstated. It removes loose soil and debris, leading to more effective overall cleaning and prevention of soil being ground into the carpet during the pad cleaning.
If you need any specific product recommendations or further guidance on technique, don't hesitate to ask!
