Peroxide Usage
yea that sounds about right...............
Ron Lippold
go easy with it I use the glug glug method with peroxide/
lester search the first page or two all the info is there
Lester:
Now do you realize just how lucky you are to have found this place?
It's clear and concise information such as this that keeps me coming back.
Hoping it will get better ... :lol:
L
lesterj2
yea i am thankful for this place...
at first everybody was bugging out but it seems everything is Kosher now...
isn't that what I said..........
M
MikeD00019
This is new to me. What does this help do? Is the ratio you mentioned Mikey for the hydro-force?
A
Able 1
I don't really now, this is 2-4 oz per gal so I'm guessing you would have to figure it out. 15oz per hydro. Is it ok to run through a HF?
Keith
C
Chads
I havent had any problems with My hydroforce but I make sure to use it up, or empty the spray nozzle they say you can have some issues with peroxide expanding and building pressure in pressurised situations like trying to put osr in your hydroforce probally not the best idea. Boom!!!!!!!!
Know what your HF is producing RTU and then add 2 to 4 ounces per.
Mine makes about 6 gallons of mixed juice so I add 6 ounces of 40 vol.
A peroxide boost helps loosen up urine, coffee and other protein spills. Also helps deodorize. Brightens colors as well. And as a extra added bonus, it burns the fat right off your skin so you don't have to think about what a broke dick you are for the next 20 minutes.
AshleyMckendree
Ashley Mckendree
It will turn your skin chalk white and tingle like a mofo, too.
tmdry
Bill Martins
...and no matter how much you wash it it will still do that for 2 days!
Now i use gloves always w/ this stuff. :D
L
Larry B
Anyone ever have problems with it removing colors from the fibers?
ronald pantelas
This week on my restaurant cleaning I started adding 1 cup of 20 volume to my prespray. I am still using the hydro force. I Did not notice a difference, but will continue this process cause so many people here say its good. Ron
Farenheit251
Ronald, One cup of 20 volume is pretty weak. Where I notice the biggest difference is on restaurants that have the green or red carpet with the white diamonds or similar. The color part always looks clean but the pop of the white is what the eye focuses on. After a couple years it is very hard to get the white to pop without peroxide.
davep105
Dave Pires
For you guys using the Sallys 40 volume, does it matter if its a cream developer or clear?
The Preacher
MOrt, you might be a V owner now, but yore humor is 16hp 33blower 1.5" hose!!!
You're just mad cuz your being gay is old news.
You could regain some of the old attention here if you'd get serious about cleaning and stop looking for a job.
SRI Cleaning
Anthony Firmani
I have accidentally gotten cream developer before. It works but does NOT mix as nicely in a hydroforce.
Nate The Great
This boost can be applied to any color carpet or white only carpet? What's the limitations? I read the other thread you posted but seen nothing of it.
tmdry
Bill Martins
I went to 2 ounces per gallon of 30 volume on my pump sprayer w/ pre spray of choice at 3 ounces, and noticed a big difference. Actually most of the stains were gone before i cleaned, also works well in spot sprayers too.
Haven't tried with the 40 yet tho.
Diluted like this I highly doubt you'll ever bother a synthetic carpet.
Left on full strength on 4th gen and older you'll pull some color someday, some how.
