- Joined
- Oct 7, 2006
- Messages
- 18,851
- Name
- Lee Stockwell
Any wire braid hose will be damaged by freezing if not emptied. The damage won't be immediately noticed in most cases. Swelled casings, and black water will warn you.
Sure, but if you've noticed sometimes hoses and tools get left too far from the heat. Not an Alabama thing...Your TM is also damaged by freezing.
So don't let it freeze.
Hoses can freeze while laying on the frozen ground too that's another reason to lay the solution line last and roll it up first.Sure, but if you've noticed sometimes hoses and tools get left too far from the heat. Not an Alabama thing...
