Parker hose
sassyotto
Wisconsin
Paul
look up any local Parker dealer. I have two within 20 miles. I like 115 feet first hose run too!
Its time for me to replace my 250’ of Continental neptune. Where should I buy it?
If you want to buy a spool, one of the Parker Hannifin plants that makes it is right down the road from me
25 years ago I called the plant and inquired about buying direct.
I could of made it happen, but it had to be a gigundo bulk spool with like 37 miles of line
I support my local vendors as much as possible but for hoses, my local hose supply shop is my preferred vendor. I get them custom made my way and cheaper.
Reactions: hogjowl
Is the only reason you use them is because the colors match your butler grey? Don’t forget to go to the salon and get your nails done also.
I buy grey hoses too. I have had problems with blue hoses bleeding on my presprayed carpets. I get a 125 foot length with ends, qd's and a high pressure shut off valve for $250 cdn.
Athens, Ga
Evets
We switched to Parker hose and I can't see ever going back
It is so much easier to work with than the Goodyear stuff, but we did need to back off the heat a little.
FB7777
I’ve bought the Goodyear blue neptune lines and had a couple issues where the blue ink has transferred , especially when the line is extra hot in the summer...
plus the grey line does like prettier 😀
Parflex. Very easy to work with and light weight.
But, like I said we did need to back offthe heat a little.
Hot heat is the only reason I don’t use that
I found that the raptor blast is the best between the two
Man. I thibnk ill stick with my continental. Never had an issue. I’m tempted to try the raptor, but i like my steel braided.
