OUT!
Jesse
Mikey P said:
Cobbs new ti wand
Sent from my DROID2 using Tapatalk
I was surprised that those wands don't have a lip separator stud. Ken says there so thick they don't need one. I guess with a glide on it you won't know it's collapsed in the center while cleaning gcd. I know they are cheap but how much more would it have cost to add the stud? If someone doesn't want one, because they use a porty or low vac unit, they can knock it out.
Otherwise they seem to be decent for a cheapo wand.
Doug Cox
Delavan, WI
Doug Cox
Mikey P said:
A new steam action design that should be@ m7f
All I can say is.............. WTF, I thought my Genesis was big.
Ryan
I like how they put the pressure adjust on the side of the machine instead of behind the pump like mine is setup. Other then that I don't see much improvement in the new design.. Does the roof help anything?
And what is upwith that rust? Mine is a 2004 model and doesn't have hardly rust on the welds.
Able 1
Wi
Keith
Mikey P said:
Cobbs new ti wand
That has to be a stainless head.. Right? How much does it weigh?
-JB-
here
JB
and.....
(sometimes it's what people don't say that says the most.)
Jim Bethel
Sunshine Coast, QLD, Australia
Jim Bethel
Doug Cox said:
[quote="Mikey P":1iduep87]
OMG!! What white trash POS would wear a belt buckle like that?
[/quote:1iduep87]
You thought his belt was bad - you shoulda seen his shoes. :lol:
CU said he has had this belt since his was 12 and the worn notches all the way around prove it. Time for a new belt Jerry!!
