OP truths.
Status
Not open for further replies.
D
diamond brian
I'm sorry Darlene, but I just can't help myself this time:
Today used my Brute OP machine, only used 8 gallons of water
half gal of Pad Pro and I cleaned 750 sq ft of Oriental rugs and 4 floors of
corridors I have been cleaning with my Porty. There is 10,000 sq ft in each corridor. 1/2 Gal of chem for 40K sq ft--Are you outta your mind?
I started at 6:00 this morn and I was done at 11:30. You've never gotten up at 6:00 am in your life!
Carpets looked every bit as clean as when I HWE. That job usually has taken me all of 4 days. You better show up and look busy the next 3 days or they'll cut your pay.
I used 45 pads . They are dirty as Mike has described. They will never look new again, but then they will be clean. I think you were drinking Colt 45s.
I cannot get over how great it is to make the same money and
get the same results for a lot less time involved to get it done.
Neither can your customer!
I cleaned the areas around tables set up in a 6000 sq ft ball room and
I got up all the spills. It took all of 1 1/2 hours to do. That's 4,000 sq/hr--slightly more believable!
Amazing. Tomorrow I have a dining room to do. 4000 sq ft.
I'm going to try and do it with the op machine first, but I am not
sure the out come will be as I have always achieved. Lot's of grease build up even though I clean it every 3 month's. Sounds like 30 minutes work to me.
I still may have to use my porty and super max. I am going to use
the Judson juice for the first time on that one. Usually I have used
the P.I.G. Stinky stuff and way too expensive. Don't you know Judson exaggerates its claims?
Let you all know if the OP machine does it or If I had to to the cleaning
the usual way.
Darlene, I like you, but you've lost your mind this time!
Jeremy
Jeremy
There is no way 8 gallons would do it. I clean with OP in fact I have 2 machines & 8 gallons each wouldn't do it. Even for spot cleaning...
SEEEEE...Religion is the root of ALL evil.......i tol you so!
D
diamond brian
Now, I'd never call Darlene a liar; I'm sure she's good as gold.
Simply questioning her mental state--that's all. :)
I think you have to be the only one around that still has any questions regarding her mental state.
H
harryhides
So it's really true that the ONLY people that Alabamans can be snobby to are the nice folks from Mississip ?
Soooo......John, you never have huh?
John......OH JOHN.....Wherrt he go....?
did jesus hep ya yet?
Well, Darlene has a pleasant personality, PadPrick. Given her comparable mental state, in relation to those two you have in your office, I'd say her personality would be a HUGE improvement for you.
May be you should think about hiring her.
John Buxton
Darlene,
Are you sure about those numbers? You'd have to clean 8,636 SF per hour, 144 SF per minute, 2.4 SF per second! I cant even walk that fast, let along set up, change pads, spot, go to another floor, etc, etc.
Thars somethin smelly in Dollywood.
That was kind of mean, Marty. The two you were referring to, one of them Patty?
Bob, you don't make any sense.
Just how many women have you encountered working in John's business, Josh?
Think real hard.
Status
