- Joined
- Oct 6, 2006
- Messages
- 117,376
Im violating some policies at my military complex...
The Contractor is responsible for all of the following:
Detailed Work Description
Floor Cleaning
• Clean all carpets and hard surfaces throughout the home using hot water extraction
as recommended by carpet or flooring manufacturer. • Truck-mount cleaning is required
• Pre-treat and remove all basic carpet stains. • Do not use excessive amounts of
cleaning agents, and rinse all cleaning agents thoroughly from the carpet to prevent
premature soiling. Do not use any cleaner with a pH of 10 or higher. Test all cleaning
agents on a small non-visible area of carpet before proceeding. • Rake all carpet after
cleaning is performed.
Floor Cleaning
