Oh Joy!
steve_64
The WM very is 5.6 the 2010 butler is a 5.9.
Been busy cleaning the basement got a bunch of rugs coming Tuesday to clean.
KSL
Kent
BUTLER MAXIMUM VACUUM/BLOWER SYSTEM
  • Vacuum/Blower customized to Butler specifications with idle, normal and Mach II speed features
  • Capable of displacing over 500 cubic feet of air per minute (CFM)
  • Includes 3" custom smooth-flow fittings, hose and couplers from recovery tank through entire vacuum/blower and silencer system for maximum performance and air flow
  • 3-position speed control switch adjusts vacuum/blower speed (air volume) for delicate upholstery cleaning, normal carpet cleaning and for “dual-wand cleaning” (Mach II)
  • Automatic belt tensioner
  • Easy view oil level indicator(s)*
  • Panel-mounted lubricating port for convenient servicing (not shown)
  • Remote oil drain valve(s) for ease of servicing*
  • Remote grease fittings with high-pressure, braided stainless steel connecting hoses located in front of vacuum/blower for convenient servicing
  • Couples to Ultra-Quiet Silencer System
  • Complimentary vacuum/blower oil for first oil change
  • Complimentary tube of vacuum/blower grease
  • Color-coded items referenced to schematic
  • Satin black finish
STOCK# K47
* The Butler Maximum Vacuum/Blower used in combination with the Butler Maximum Heat Exchange System has two gear cases with oil indicators, drain valves and no grease fittings.
Reactions: steve_64
steve_64
I questioned the low speed rpm but it's not an issue. I'm very happy with my purchase.
steve_64
Yes, 47.
I hate weasel words used by otherwise reputable manufacturers.
Honestly, it was my own fault for not doing my research. I wasnt mislead or anything. Like buying the WM everyone was very honest and informative. I made an assumption and it was me that was incorrect.
. I wasnt mislead[ing] or anything.
I was sure of that, Stevo
I don't think anyone here thinks you're a bullchitter
just a weirdo :lol:
Lovable one, but weirdo nonetheless ....:icon_razz::icon_razz:
only reason I was pretty sure, is cause I asked many years ago about their "5-8" marketing
Reactions: steve_64
Yes, 47.
Saying “it’s capable of 500cfm” is far from the facts of the specific performance. All these manufacturers do that. It pisses me off
steve_64
When I heard big blower I assumed a 59 and when I get things in my head it's hard to change. I need to be corrected several times before it can be erased and that's why I like it here on MB. You guys will beat it out of me! That's a good thing. It doesn't offend me.
