- Joined
- Aug 9, 2012
- Messages
- 11,571
- Name
- sam miller
Chemspec crystal powdered defoamer is the best
Rubbing alcohol?Almost any non detergent solvent cleaner will do. Volatile means fast evaporating.
Vodka.Rubbing alcohol?
I've never tried it. I usually carry a volatile solvent spotter with me. A couple squirts in the vac hose cuts the foam. Harvard pogo is a good one but anything similar.Rubbing alcohol?
Most volatile solvent carpet spotter's are not flammable. Rubbing alcohol isDO NOT put much flammable stuff (wd-40, alcohol, Solvents in general, etc.) in vac hose of a portable machine as the spark from the motor may start a fire. Ha ha.
I also have a habit I developed over the years, stop communicating with people who have one foot in the grave, that way you don’t miss them as much when both feet are in.
It works in a pinch
That never even occurred to me. I've used salt in my beer before to knock down the head, but never thought of it as a defoamer. Great tip!I have used regular table salt as a defoamer in a pinch as well.
Like saigers says bring on the boomDO NOT put much flammable stuff (wd-40, alcohol, Solvents in general, etc.) in vac hose of a portable machine as the spark from the motor may start a fire. Ha ha.
Many defoamers (and fabric softeners) use cationic silicones, which can bond with the factory applied fluorocarbon protectant on the carpet.I've only heard of defoamer products possibly damaging carpets but never experienced it..
I came to this because a client was moving his wine collection in a laundry hamper (construction), and the bottom broke out.Most acidic stuff will cut foam.
Just like spraying your car interior with Armor-All. You may create a sticky residue that attracts dirt and is almost impossible to remove. It's why the silicone protectant scammers of the world have mostly gone away; too many claims.
I'd recommend sucking handfuls of whatever you're using into the vac hose rather than casting or spraying on the carpet.
PS: I have seen carpet damaged by silicone sprays, only because it got dirty so fast (and couldn't be cleaned) that it was easy to point to who did it. In several cases the carpet had to be replaced.
Any advice for a portable with auto-pump out?Most acidic stuff will cut foam.
For severe foaming, do what Jim suggested with the sponge but also spray through your vac hose with a liquid defoamer. You may have to do it often with something as severe as that. I've done similar when a customer dropped a bottle of laundry detergent. Get some in your waste tank before you start and keep spraying through vac hose periodically. A spray works better than a squeeze bottle. Do not put the defoamer on the carpet.Any advice for a portable with auto-pump out?
I was water-clawing carpet with 15 bottles of wine spilled into carpet.
Followed by wife then house cleaner working on stain and smell before they called me.
Keep applying defoamer or acidic juice when needed?
