Need help with blower issue
C
carpetman727
I recently changed my blower oil, set the levels at the half way point of the sight windows. After a few days I checked the levels and one of the sight windows shows almost empty and the other shows full to the top. It's in a 2012 Hydramaster CDS 4.8. Any help would be greatly appreciated.
Papa John
Lifetime Supportive Member
John Stewart
was your TM on level ground? was the blower running when you checked the oil level?- this would lower the amount seen in the glass
C
carpetman727
No, it was on level ground, machine hadn't been running since the previous day
Check it with a level to make sure it's flat.
Papa John
John Stewart
Maybe there was an air pocket in drain hose and after a little more time the oil that was in the site glass drained to fill that air pocket?
Refill again and that might solve the problem.
Remember-- after any oil change, the instructions are to check the oil level again after a day or two.
