Judson 02 prespray
vincent
O'Fallon, MO
Vincent Sapp
Who uses it in a hydroforce and what are your fix ratios?
Also do you apply it at the same psi you clean with?
Jesse
For us, usually 16oz per 7qt sprayer 1:4 (no tip) applied @ 800psi unless it's a really dirty then 500psi draws better, I'd go to 300 if I was treating a bad spot but usually it's better to make a stronger mix and save the time @ 800psi.
We soak em so psi save lots of time
I also add things to it besides the modifier.... It's compatible w/ everything I like to boost with.
sweendogg
Bloomington, IL 61704
David Sweeney
Yes its thick.. shake well before pouring and before using in the HF. we use 16 oz at 4-600 for most jobs. If I think it needs the Hot Sauce I'll add five heaping teaspoons. It has taken care of everything I wanted it to when I use it. If its really dirty and I know ahead of time, I'll go nuclear on it with Grease Eraser or other high pH like powerburst, enzall, etc..
Shane T
Waukesha, WI
Shane Tiegs
Tom Meyer said:
8 to 10 ounces for one gallon of water in the Hydraforce, 500 PSI and no tip.
Ditto! Notice this without a metering tip. With this setup it even pulls chem at 200 degrees.
Latest Auctions
