- Joined
- Oct 2, 2007
- Messages
- 10,952
- Name
- Willy P
I'm a 4 cord dude. 2 for a 500 PSI pump, dual 3 stages and 2 cords for heat. Just a little THOUGHT put into where you place your plugs and it;s not a problem.
I don't think that what I have works as I say it does, I know it works, because I've spent decades fine tuning machines, both electric and gasoline truckmounts.brother Martin said:Ok then, but please don't get your feelings hurt when I say that's ANOTHER bulletin board disconnect between whats reported as possible and what reality seems to suggest.
I'd love to actually see that.
Is there a reason, you think, why your results are different than what other people, and suppliers, report is possible?
Something you may not be telling us?
It is truly amazing what you wet cleaners will go through just to stay wet. Them manufacturers sure got you guys wrapped around their fingers.Willy P said:I'm a 4 cord dude. 2 for a 500 PSI pump, dual 3 stages and 2 cords for heat. Just a little THOUGHT put into where you place your plugs and it;s not a problem.
Mardie said:It is truly amazing what you wet cleaners will go through just to stay wet. Them manufacturers sure got you guys wrapped around their fingers.Willy P said:I'm a 4 cord dude. 2 for a 500 PSI pump, dual 3 stages and 2 cords for heat. Just a little THOUGHT put into where you place your plugs and it;s not a problem.
Cat piss goes on Tuesday.Caduceus said:Mardie said:It is truly amazing what you wet cleaners will go through just to stay wet. Them manufacturers sure got you guys wrapped around their fingers.Willy P said:I'm a 4 cord dude. 2 for a 500 PSI pump, dual 3 stages and 2 cords for heat. Just a little THOUGHT put into where you place your plugs and it;s not a problem.
Not much impact from a guy who knows little about the industry. :roll: Ever flush all that cat pee out?
If I were to use a water flushing technique to get rid of that cat piss the carpet would be wet for a month and to put it simply the whole job would be a gong show.Caduceus said:Seems like your customers arent educated in the proper method of cleaning.
Good luck at flushing at the urine.
I got to hand it to you Willy,you sure are a dedicated man.Willy P said:I'm a 4 cord dude. 2 for a 500 PSI pump, dual 3 stages and 2 cords for heat. Just a little THOUGHT put into where you place your plugs and it;s not a problem.
Royal Man said:[quote="Willy P":4aw1q3rp]I'm a 4 cord dude. 2 for a 500 PSI pump, dual 3 stages and 2 cords for heat. Just a little THOUGHT put into where you place your plugs and it;s not a problem.
Mardie said:If I were to use a water flushing technique to get rid of that cat piss the carpet would be wet for a month and to put it simply the whole job would be a gong show.Caduceus said:Seems like your customers arent educated in the proper method of cleaning.
Caduceus said:Mardie said:If I were to use a water flushing technique to get rid of that cat piss the carpet would be wet for a month and to put it simply the whole job would be a gong show.Caduceus said:Seems like your customers arent educated in the proper method of cleaning.
I have been doing HWE extraction for 14 years and never had that problem happen. Is that what you read on ChemDry's website or something?
Going to mix 2 Bridgepoint products together Hydrocide Extreme and Pet Zone into the cimex (My Cost $170.00) then scrub it in so that the carpet is quite wet but not soaked, first thing in the morning, then put some air movers on it to dry.Will take extra time because i have to boil the water.Going to bring some big pots.lol Then come back at 5-6pm to clean.( Price for cleaning $225.00 .40sq ft.) Price for One and only treatment ( $540.00)Caduceus said:Mardi how much you charging for the job and how much time you are projecting to complete it?
Marty said:Chavez:
It didn't escape my attention that Willy just called you insane.
I love Willy's insults. I didn't get that one though.Willy P said:Marty said:Chavez:
Hold the cursor over this:
hey Marty, blow me
Mardie said:Going to mix 2 Bridgepoint products together Hydrocide Extreme and Pet Zone into the cimex (My Cost $170.00) then scrub it in so that the carpet is quite wet but not soaked, first thing in the morning, then put some air movers on it to dry.Will take extra time because i have to boil the water.Going to bring some big pots.lol Then come back at 5-6pm to clean.( Price for cleaning $225.00 .40sq ft.) Price for One and only treatment ( $540.00)Caduceus said:Mardi how much you charging for the job and how much time you are projecting to complete it?
Mikey P said:Is that before or after you start posting on ICS?
