- Joined
- Oct 6, 2006
- Messages
- 117,390
Bigger would help us hacks who have the customer vacuum, and they miss areas or have a lot of pet hair.
why?I like bigger holes in the hole glide with the last 3 holes notched out for along the baseboard.
I am Slow. I do 3 to 5 wet passes and double the dry passes.You live in an area where you can charge absurds amount of money, If you just slow down a little bit and provide a perceived value, why aren't you taking advantage of that?
think I'd rather give a thorough vacuum and drop a couple of wet passesI am Slow. I do 3 to 5 wet passes and double the dry passes.
The other day I was using the Rotovac Monsoon. It felt like it had minimum suction. When the lady walked on the wool carpet I had just cleaned 30 minutes earlier; she claimed her socks were dry.
There’s an inch of snow forecast here for the day after Christmas. Last time it snowed was 2012 or 13. Might actually have to winterize the TM
I like the bigger holes when running with the Aerotech. I believe there is more airflow and I get better dry timeswhy?
I personally do not like the hybrid because of the lines they leave, the hole glide does not dig in to some carpet like the slot glide. just my opinion.
I do not notice the larger hole making a pattern.I haven't used a large hole glide option so excuse my questions, but doesn't it leave lines as well? They're just more consistent rather than the dot dash dot dash?
