Interview with Mike Vernon 11-15-06
Fred Homan
Is it possible to use Soil Blocker after Cimexing using Rick's DS?
A
alazo1
What's the easiest way to test carpet to see if protector is needed.
Albert
Jeremy
Jeremy
Not to cut in line, but...
Does the re-application of protector extend the life of a carpet? If so by how much? Is there a reason to not over protect (other than cost) or protect brand new carpet?
I am going to answer Via Mike..
Thang..
Most likely you are not using your sprayer enough and the SB is drying at the tip..
Add six ounces per gallon of alcohol to your SB to keep it from gelling up in the tip of the sprayer.
Also store your wand with the tip point upwards.
Scott Rogers
Are you going to have your products CRI certified?
What are your thoughts on the new standards coming online?
Easiest way?
Pour water on a area in a traffic lane, if it absorbs in right away it needs a reapplication.
Is there a reason to not over protect or protect brand new carpet?
Under normal traffic conditions, I would wait one year to re apply a protector...
Jeremy
Jeremy
Mike & Mike thanks for your time & knowledge. Have a great night.
Not at this point.....
I want to wait and see where this whole thing goes...I am no hurry to spend 25K to do the "Testing"..
As a professional I am not sure how I feel about people OUTSIDE our industry dictating what we do...
truckmount girl
Mike,
Some (dry chemical) companies mix protector with their cleaner...is this a viable mixture?
Take care,
Lisa
truckmount girl
Another question; Do you feel solvent based protector is safe to apply to carpet (whole house) in an occupied building?
Take care,
Lisa
Water based protectors can be combined with many other cleaning solutions,
Whit the "Dry" method you will leave SOME protection behind but the full effect will be compromised and not as effective as the traditional application.
Yes and or no, it depends on the occupants of course..
If it's an 85 year old person with emphysema the answer is no.
You'll have to use your judgment.
When applied correctly the answer is yes ( adequate ventilation and keep the applicator tip below your knee.)
If the guy applying it reacts to it he should defenatly wear a respirator. Usually the person applying it will know right away if he can handle it or not.
Jeremy
Jeremy
"Under normal traffic conditions, I would wait one year to re apply a protector..."
If you don't mind me asking... Why?
The Technical Life + 2 years.
Mike V's opinion is one year.
But why would you have it around more then a month anyways??
You have to pick a time frame a based upon the usage of the carpet. One year is average.
It will be up to you, the professional to decide what is best for your client.
In very heavy use areas you could re apply SB every six months form the get go and not be cheating your clients.
Thang....
Spend a little time with Mike on the phone and he'll have you moving a case a month....
No problem.
Jeremy
Jeremy
So there is no benefit to "suplimenting" the mill applied protection?
Two trucks, two man crews, Hydramaster 421 Boxxers.
Rural market.
Only 17,000 people in our 40 mile radius.
We own the market share.
Referral only. No advertising at all.
98.9% residential work.
9 out or ten reapply protector at some level each visit
No Jeremy I dont think there is any reason to do so on a new carpet.
Well Mike...I am sorry we had the Computer glitches tonight..
I want to thank to thank every one for hanging in there..
I also want to let everyone know that Mr Vernon is going to do his best to come out to WinterFest so you can drill him in person..
Fred Homan
i think I'll be calling Mike Vernon tomorrow morning to chat/order a multi sprayer and some Soil Blocker. Thanks Mike and Mike.......
