- Joined
- Oct 6, 2006
- Messages
- 117,396
How does this compare to the Cobb light power wise?
Lordy that dude looks small for $400.00.
I think I saw them in a bin at Harbor Freight. 2-for $5.00.![]()
I like Cobb's but we don't use it very much. We don't do much pet urine work. Its used mostly for inspection to show them how severe the damage is and why it needs to be replaced.Cobb's is the best bang for the buck......
If they replace the pet, I move in for Free room & board. I also promise not to piss on the carpet.How much does Cahvez Resto sells them the new pet for?
You guys give the term "full service company" a new meaning.If they replace the pet, I move in for Free room & board. I also promise not to piss on the carpet.
Yep, I'll piss on the upholstery & tile.![]()
I think it can be done effectively but its usually more expensive and extensive than most people want to get into.
Disengage the install, remove the pad, clean the subfloor, seal the subfloor, remove affected tack strip, possibly lower drywall clean & treat both sides of the carpet, new pad, reinstall.
All so the Fido can start the cycle all over.![]()
Looks like its a 4 LED flashlight. 2 LED's and 2 UV LEDS. The ad doesnt say wattage. Cobbs is supposed to be a 7 watt Single Bulb high power UV LED. Where I am going to go out on a limb and guess that this is 2 3 watt LED's. But I would love to see a UV light off between the two.
But the results would probably be inconclusive.
Each LED is 3 watts for a total of 9 watts.
That light has 3 UV LEDS that operate at 385 nm. Each LED is 3 watts for a total of 9 watts.
I guess I need to check this Interlink light a little better - it might be a better overall deal after all. I just went to Cobbs website to actually buy the UV light talked about here for $239 and when I went to purchase it the only shipping option was going to cost $46!!!! That's a tad much for something so small and light.
(BTW - I did try calling Cobb's to ask them about it but it was after hours)
