Ink on carpet
W
Warren Wallace
sounds easy enough well ?It kept getting darker and darker
ive cleaned ink plenty of times but this just kept going threw
everything except kitcheon sink at it,left with just a faint circle
sprayed stain magic and put a white towel on it and left.I told
her i would come back if needed.What a pain in the ass
A
alazo1
Try sucking it up with your vac hose if it keeps on bleeding. Rubbing alcohol is fairly inexpensive and may put it in suspension. It won't get it all out but may reduce the time it takes. Sounds like you went through a lot of chems, that sucks.
Albert
rhyde
rhyde
Rubbing alcohol works well on some spots I’ve been using Vacaway’s PIG it works great
