If you were to build a TM today?
Sierra Clean Care
Taking all into consideration, being able to complete any task, T&G, hard surfaces of any kind, of course carpet, whether long run commercial, high end residential, section 8 rental, And budget wasn’t an issue,
What would YOU build?
ANY base platform..
(One critical point, I need performance up to 500’)
Same. 870 is a mean machine.
Maybe a box truck if I didn't have a lot of trees and a garage tall enough to house it.
I love the Transit ride but with so much equipment needed to be able to offer a variety of services, I'd buy a Spartan box with a Transit cab, with an 870 in the box.
Then flip off all my jealous competitors! Well, at least Marty anyway! 😎
Just copy an Aerotech.
And for 500ft, have your solution hoses to be 3/8" almost the whole way to insulate the heat better, and have a minimum of 250' of 2.5" vac hose.
Better yet, just BUY an aerotech. Don't be cheap. I saw that house you bought. You've got the money to buy one
Larry:
How many jobs do you use a roller on that can’t also be painted with a 2in brush?
ANY base platform..
Already been done. The Everest 650 hp was a beast. All the heat you need and enough vacuum power for 500 feet or dual wanding. Guy in Alberta has one for sale for $17,900. 2009 Everest in a 2005 long wheel base Savana one ton.
What percentage of jobs did you run 500ft of hose when you had a Vortex, Marty?
Very first job I did with it. Two 250’ hose runs with the dump valve open. Couldn’t tell until done and found the parking lot full of dump water.
Sierra Clean Care
Well, I’m on a job RIGHT NOW, I’m running 450’, because there’s road construction out front, and I’m parked in the next lot over, cause the parking is underground…. Got another monster job on Wednesday, between 375-400’…
Why not encap? Cause it’s a post Reno clean up….
And fook no, I’m using a porty on 5 floors of a commercial building….
Nobody ever wishes they would have bought smaller. Go big or go home!
Small brains, small heart, small strength, small pecker, small tm. Let the other po saps go small! lol
Seriously the big units are built for the long haul. Built for extended length, high heat, dual wands. As your company continues to evolve it will be the foundation of your business.
why aren't you running a megamount now?
I don't regret getting rid of the smaller machines and sticking with the big Everest 650. I did 300' today for 8 straight hours non stop and it had an awesome bite on the commercial carpet.
Big is the only way to go. If I have a small 100' job, I just get through it faster.
But really, there's no need to build a tm.
If I built a TM, I would ensure it had cup holders.
Reactions: FB7777 and BIG WOOD
Rob Grady
Rob Grady
I wonder why the Everest in Alberta isn't selling? It's been advertised for quite a while. The seller should post better pics and maybe wash the van a bit?
Rob Grady
Rob Grady
It seems to be priced right and looks to be in decent shape, and the hours are reasonable.
He doesn't want to include a wand or other accessories it seems. Wants to keep them for his portable. Not an issue for me but I really don't want an extended length van. The unit is 2009 with low hours for an everest.
Rob Grady
Rob Grady
No extended for me either. I passed on an Everest three years ago for $17 machine two large hose reels and double axel trailer included. It was showing around 500 hrs and was used for cleaning churches.
