I've got a bunch of co2 tanks from my paintball years, and I can fill it myself also. That's a good ideaI built mine . Using a longgray 1.5 gal stainless pump up a kleanrite inline quick connect filter 10' hose and gunjet off my hydroforce sprayer and a rechargeable air compressor from Costco. The compressor in in a bag i bought from patriot sprayers. They sell a sprayer that uses a paintball gun co2 bottle to maintain pressure. been using it for yearsno problems even have a dedicated charging port built into my truck to keep it charged i like the patriot sprayers idea of constant pressure but there's no place close for me to recharge the co2 cylinders otherwise i would have bought 1 of them with a spare bottle and modified the hose. A friend of mine stains concrete and uses um and said that the patriot sprayers are expensive but last forever with little or no maintenance . I got about 200.00 in mine
View attachment 131254 View attachment 131255 View attachment 131256 View attachment 131257 View attachment 131259 View attachment 131260 View attachment 131262 View attachment 131263 View attachment 131264 View attachment 131265 View attachment 131266 View attachment 131267 View attachment 131258 View attachment 131261
Thanks hope it works for ya. I would like the constant pressure that co2 would allow. As it is now i set the pressure at 60psi and when it drops to around 40 i have to hit the button on the air compressor. Look up patriot sprayers you can just buythe pressure regulator and bag and hang on any sprayer that has a Schrader and relief valve like the longgray.I've got a bunch of co2 tanks from my paintball years, and I can fill it myself also. That's a good idea
Does the corded multi-sprayer spray more powerfully than the battery powered multi-sprayer, or are they about the same with output?I like my corded multi-sprayer. Puts out the right volume for me
which is why I started this threadMine are all broken.
I've never used the battery powered one. Not a fan of most battery powered equipment. I find it's a pain to be charging or making sure your device is charged. Corded always works for me.Does the corded multi-sprayer spray more powerfully than the battery powered multi-sprayer, or are they about the same with output?
The Multisprayer with the new Milwaukee lithium is great. I believe the battery versions are 50psi and the electric is 70psi.
Well whatja end up withWhich one do you guys use? I don't want to use my penguin
