Hydromaster CDS question
this is a old picture of my CDS on the top lid there are the 2 grey 90"s
I guess you all call the 4 to the door with the two .2 inch hoses and the "Y"
do you hook both the 2 inch hoses to the 90'S or is there a better way of doing this
I did not have mine long enough to get it involved with all this high performance stuff...........
Rex Tyus
That CDS is similar to what I had on my Cleanco Q56. You can y the two 2" as you described and then 2.5 hose, or you can get a 2.5" upgrade from Greenie. All you will need is a whole saw and a drill. Since you are probably not gonna try and dual wand with that CDS you would only need the single port upgrade. Hope this answers your question.
Shane T
Shane Tiegs
Jim, Is that a standard RV exhaust fan in the ceiling? Do you remember how high it protruded out the top? I don't have much clearance to get in my garage and have been having trouble finding something that will work.
approx..5 and a half inches.........
closed down tight.........
sorry but this is the only picture I have that shows the top where you can see it and get a good idea.........
Shane T
Shane Tiegs
Thanks Jim. I may just have to build a taller garage. :lol:
the van with out the vent would not fit into a standard height garage buy our/Tucson building specks.........we would of had to get the 9' custom opening when we were going to have a home built and the typical is 8' here.......
if that helps any
