HOW TO APPLY COBB'S TILE AND GROUT SEALER?
Jimmy
Spray or pour down the fist coat, work it in with the flat finish mop make sure you see all the grout lines go dark.leave enough product on the grout (and tile if it's stone) so it's noticeably wet. Now go pack up your truck or clean something else.
Go look at the floor, if it looks exactly the same and ALL the areas are still visibly wet, your done. More won't go in so don't bother. That's rare though. This means the last sealer used was excellent stuff, or its a vinyl floor and you're a moron.
If you see dry spots then apply a much light amount then the first coat, massage it in again, leaving the grout a little wet, again. Start from the back and work your way out. Remove all streaks and foot prints.
If no one will be home for a few hours you can now leave. The excess will flash off. Open some windows and turn on a ceiling fan in another room, not the sealed rooms or they'll dry too quick.
If they are home and need to walk on the floors, give it ten then blow one of your fans into the room and in a few minutes the excess will flash off completely.
Instruct them to not get the floor wet for 24 hours.
Send or give them care instructions on how to flat mop with a nuetral cleaner.
Welcome to the Cobbslop generation!
Your body, helpers and wallet will thank you.
Reactions: jcooper
CJ-FL
Florida
CK-FL
Jimmy
This is how you would apply to Groutlines installed on Ceramic and Porcelain tile? Does the product not leave any residue or haze on the til itself?
floorguy
Utah
Doug
I use Jim Martins rapid seal to hit the lines, and then go over with the micro fiber to pick up extra/spread it around... ZERO haze, and gives it just a tich of protectant on the tile (not that ceramic needs it)
Dallas, Texas USA
Even ceramic tile can absorb up to 5% of our Ultraseal Impregnator.
That makes it easier to clean for the homeowner or service person.
We now have the Impregnator with a state-of-the-art UV absorber.
It has passed stringent Zenon lamp UV testing with the highest #5 rating.
Those red tiles that lose all their color quickly in outdoor sun exposure,
can now retain their appearance many times longer.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=78&products_id=5150
Reactions: Nomad74
Dallas, Texas USA
The American National Standards Institute (ANSI) has developed a rating system for the moisture absorption of tiles.
(Typical Medium density) Ceramic Tile with absorption of more than 3.0 percent, but not more than 7.0 percent.
This is why a solvent-based fluorochemical can prevent staining & enhance cleaning on ceramic tile surface.
Even some Porcelain tiles can absorb a couple of percent.
Fort Worth , Texas
I walk through cobbs sealer every time I apply without issue.
The only instance I am mentioning was last year in st Pete at the hotel Cleaning as 20 something people were trampling over the sealer as we applied it.
1 or 2 tech walking ain’t going to mess anything up at all.
Old Coastie
Heart of Dixie
Stephen
I spray it on my shoes to keep them from looking shabby for a long, long time. The soles wear out before the uppers look worn.
