How long do you leave prespray in you inline sprayer?
Johnny
La-Z-Boy
Johnny
How long will you leave prespray in your inline sprayer before dumping it? I usually dump it at the end of the day, but if you have a job the next morning or even the following Monday after a Friday job that requires the same formula, i.e. Extreme and H2O2, will you mix fresh or dump? How long does it take to deteriorate in the jug?
Much obliged.
Reactions: Living The Dream
Johnny
La-Z-Boy
Johnny
Seems I've wasted a lot of chems over the years. Mixed fresh prespray and rinse every day.
  • Wow
Reactions: Nomad74
I've now lost count of how many carpets I've encapped with just water running through the machine and the wet microfiber pad.
I go to refill the jug and my 8-oz cup of super duper pixie juice that's still sitting there from the last supposed fill up...
Montana
Swani
You should be more alert?
Montana
Swani
Much obliged.
Usually I don't have much left especially when using 4:1, but when I do, I just mix up a new batch and add it in for a little boost, unless it's someplace with nice carpet. Then I'll just dump it in the waste tank and mix a new batch to the carpets needs.
Reactions: Johnny
Much obliged.
The soap salesmen sure do respect that you are reliable in keeping your prespray fresher than a loaf of bread in your cabinet.
DAT
Nevada
Bill Cheryl
Thats why i use way less encap for most of the cleaning. If it says 4 oz per gallon, ill use 1 oz per gallon. It works..
