High HG truckmounts better?
There isn’t any blockage
It’s called a 410everest blower trying to suck air through 1, 2” hose.
If I had a 4” hose laying on the ground, it would probably be around 6hg
Where’s Damon?
Hey Damon, go do a stupid test and show us what your hg is with 100ft of hose hooked up.
These guys with the little gas powered rug dr machines think they have suction
Where’s Damon?
Ill bet you $5000 my HWE'd carpets dry quicker than yours...
And are just as clean.
Hack Attack
Dan
move the truck.
You're parked on the hose... 🤣
it's been so long since I spun a blower, but memory suggests 100ft of open 2" hose was around 6-7 hg
(45 spun @3200 rpm)
my 36 unit spinning at 3400 is similar
haven't played with 575 yet.. sigh
Hack Attack
Dan
Where’s Damon?
providing the filters are clean the hg shows the vacuum in the whole system, as vacuum increases your cfm goes down
dont know what your blower spins at? But prob pulling 400+ cfm around 8" but below 370 cfm around 14" looking at specs for 410 around 2600 rpm
Where’s Damon?
Matt, I just saw this. Been working my tail off. Taking off for a week camping. It was a great day. Lots of big checks came in. We eat steak tonight.
you live in negative humidity. I remember someone else telling me he could get awesome dry times with his 33 blower after running 400ft of hose in Nevada. You live in the Fooking desert!
be thankful he didn't buy that open porty on a dolly cart he considered for a minute before moving to Dead Brush
we'd be hearing you don't need anything bigger for billionaires and ranch widows 🤓
Reactions: Mike Pailliotet
speaking of that goofy set up..
what ever happened to that guy?
Did he sell any of them after you stopped talking about them?
DAT
Bill Cheryl
I remember Tom saying that his custom machine is always at 10hg-11hg, and gave good explanation about it why that isn't necessarily a bad thing.
So would a 47 blower set at 17hg be a night a day difference compare to 47 at 14
On your wrists also the 405 had a governor and adjust throttle to load.
Most machine over come this by running higher rpms and fuel consumption
Prevents lockdown
move the truck.
(45 spun @3200 rpm)
That's why masterblend uses a 1 1/2 inch hose and gets 10 on a open hose run.
#restriction
I have a low mileage Chevy express sitting after my Everest was stolen out of it and I replaced it with a complete unit (butler)
Lately I’ve been needing another unit
I am looking for a 45 or 47 blower machine
The steamaction machines seem nice and even though I said I wouldn’t buy one because I heard half the story of a problem a customer had I would now knowing they did make it right
My buddy bought one with the 6008 blower and says it’s insane and he cleans mostly on idle and he says it makes his Everest hp seem weak he tells me he loves it and would buy another unit from them
So my question is a similar size blower ran around 13-14 hg vs steamaction 16-18hg what will be the difference as far as dry times and performance
Ps tell Renaldo to quit banging Paul.
16 to 18 hgs equal carpel tunnel
Reactions: Mr Brightside
Which is why I need my hg set around 14-15
I demoed the everest with two prochem ti and both on 50 ft hose run albeit a crappy carpet to clean.
Heats great.
Didn't believe it was worth the extra money.
But then I got a pro1200se so there's that.
It's great lots of suck.
Heats great.
A 150ft double hose run would be more accurate
