Fresh Water Tank Setup
Blue Monarch
Dirk Wingrove
OK, I got my tank and FloJet pump. The next question is where to put the pump. Should I pump from the tank to the water softener, or pump already treated water to the machine? I can't see why there would be a difference, but thought I'd make sure first.
Water from house --> Softener --> Tank --> Pump to machine
OR
Water from house --> Tank -->Pump to Softener --> To machine
I go straight into the softener and from the softener into the tank.......
so every drop that goes in and out of the fresh water tank and the truck is softened water..........
steve frasier
Jim
what do you use to bolt stuff to the fiberglass panels
I will have to install a water softener and insulation, would like some ideas
thanks Jim
but yes, go through the water softener first
I have not put a single hole in the fiberglass...........
the star bolt that are all around the top, bottom and the sides holding the fiber glass panels on the truck are 1/4....20 bolts..........
I just bought longer ones and hung hooks on them........
as far as insulating it.......
what I would do is get 1/2 inch Styrofoam and put it up and then get 1/4 inch white mar-lite and hang it over the foam.....then you can drill as many hole in it and not worry about the fiber glass..........
you will do 2 things..........insulate the side and help sound prof it at the same time......
